Proper tire pressure?
/ Proper tire pressure? #1
2dawoodz
Checked a friend's tire pressure on his Ford NH 1920. Front was 21 and rear was 6 & 8 psi. Rear seems low to me but little sidewall deflection. Not sure how much sidewall deflection I should be seeing. Owner does not have a manual. Thanks.
/ Proper tire pressure? #2
rear tires generally run lower psi... as a rule of thumb i air them up till the look good in profile. it's a bit of a compromise between tire patch, traction and were pattern.. also have to consider load carried and bulge.
i don't even use an air gage anymore. just air em up till the 'look' correct.
i know there's a science to it.. but you can do it like it's an art and it works out just as good.. ;)
soundguy
/ Proper tire pressure? #3
I keep my tires, all 29 of them:eek: including the wheel barrow eyeballed below but near the range of the max PSI stamped on the tire casing.
/ Proper tire pressure? #4
A lot depends on whether or not there is a LOADER.
Over 40 psi is not uncommon for R4s on tractors with loaders.
The Firestone web site has/had a load/pressure table for just about every tractor tire.
The max pressure molded into the sidewall is only suitable for max load - generally a bad idea to run at that pressure, also a bad idea to be loaded at or close to the max anyway.
For field work you generally want drive tires "a bit squishy" {a very precise technical term}
You can read the soil to detect slippage - it takes practice (-:
/ Proper tire pressure? #5
I run my BX rear tires so that I have full tread on the ground when I'm on concrete. Fronts are at or near max presure because of the front loader.
/ Proper tire pressure? #6
I would caution anyone working on inclines about just eyeballing and guessing at tire pressures. Old tires that have hardened over the years don't show sidewall squat as well as newer tires.
Did the tractor roll over because the tire bead broke from the rim or did the roll over cause it to break away. If the operator is dead the investigating team may never know. I've used both eyeball and gauge methods and in my younger days I've even kicked a tire or two but in later years I prefer the gauge. It doesn't hurt my toe so bad.:D
This tractor does have a front loader and 4x4 ability. I just wasn't sure about running max pressure like I do in my street vehicles. Thanks for everyone's input!
/ Proper tire pressure? #8
Seem to remember an old rule of thumb with ag tires was one bar on the ground and two others touching. I'd guess that at maybe 10 #??
Jim
/ Proper tire pressure? #9
imho.. if the side angle is soo bad that a couple inch drops makes for a roll condition.. you already don't need to be on that side angle.
soundguy
/ Proper tire pressure? #10
I run my fronts at max allowable and rear at 18.
/ Proper tire pressure? #11
First thing to check is whether you have bias or belted tires. Belted are significantly more expensive tires. Belted are much better for traction because the sidewalls have more flex and allow the tread to increase contact to the ground. If you have bias (most folks have because all tractors are sold with them as far as i know), then lowering the air pressure down to 5-10 psi is needed to get R-4's treads to fully contact the ground. This principle applies to surfaces that allow for the tread to bite into it.
For surfaces that resist tread bite, the best traction is when you get maximum weight on the smallest footprint, assuming the tire has aggressive tread (e.g. R-1's).
Jim
Bestway 40ft Sprayer (A64047)
Bestway 40ft...
UNUSED ATS 4'X300' GRASS PROOF CLOTH (A62131)
UNUSED ATS 4'X300'...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
SINGLE AXLE MOTORCYCLE TRAILER (A62130)
SINGLE AXLE...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
John Deere 7320 (A62180)
John Deere 7320...
