Proper Technique for Chaining Tree to FEL?
   / Proper Technique for Chaining Tree to FEL? #1
BoneheadNW
Washington
Kubota B7610
I've done a search and read some posts on how to lift sections of a tree using bucket hooks and a chain. I know to keep the load as low as possible during transport but what is the best way to attach the chain to the tree and bucket hooks? I remember reading one post that said to use only the center hook so as not to imbalance the load to the left or right on the bucket.
Suggestions and pictures would be great!
Bonehead
   / Proper Technique for Chaining Tree to FEL? #2
How long a 'log' (tree section) are you talking about? I assume you are thinking of carrying it cross-wise to the tractor in the bucket?
I would, if I did such a thing, pick it up with a chain and find the 'balance point, then with it balanced, I would chain it to the bucket with the end hooks. Drive slow. I use the forks to carry logs that way.
Some carry logs 'parallel' with the tractor, using logging tongs (search will get you pictures) attached to the bucket, and the log slung under the bucket. This takes some care and talent to keep the log sticking straight out to the front.
   / Proper Technique for Chaining Tree to FEL? #3
I can't answer your question directly, but this job, moving large logs is what got me looking into pallet forks. I bought a quick attach system and forks. Now I use the forks for many more jobs than I use my bucket.
   / Proper Technique for Chaining Tree to FEL? #4
i usually chain them to the fel or the 3pt and drag them till i can cut them up, i like to lift the end up so it does not snag on the ground, a lot really depends on the size of the log and what exactly u are trying to do with it.
   / Proper Technique for Chaining Tree to FEL? #5
If I'm just moving logs around I chain them and drag them from the drawbar. If I need to lift them for loading onto my trailer, I use two choker type loops of chain as tight as I can get them, roughly six feet apart. The running end of each goes to a grab hook on the ends of the bucket, with as little slack as possible. This method eliminates the log twisting or spinning and minimizes swaying. Carry it low, move slowly, and keep counterweight on the rear.
2025 CFG Industrial QK16R (A50123)
2025 CFG...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
Mitsubishi Mini Truck, 3cyl Gas Engine, 2WD (A52384)
Mitsubishi Mini...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2016 Mobility Ventures MV-1 Van (A51694)
2016 Mobility...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
