proper placement of set screws
   / proper placement of set screws #1
dqdave1
N. E. Ohio
tc- 29d
I broke a piece off the end of a drive axle on my zero turn mower. I made a replacement stub with a coupler to slip over existing axle. I need to know proper placement of the setscrews to get max holding power. Do you place them 90 degrees apart or 180 degrees apart? I think 90 degrees is best. Any advise is welcome.
   / proper placement of set screws #2
90 deg is best. One over the key and the other on the shaft. If they keep working loose you can demple the shaft with a drill point the size of the hole and run it down. You can put in a long screw and run a nut down the part sticking out to jam the threads. If the hole is deep enough you can put two screws in the same hole on top of each other. I have also seen a ball bearing dropped down a hole over a demple in a shaft and a set screw on top of that. I like to use never seize on things I put back together because I might be the next one taking it apart. Maybe this is all more than you wanted to know.
Dan
   / proper placement of set screws #3
If you're using the setscrews to hold the sleeve in place, you're probably better off to weld it instead. With the load of a drive axle I doubt the sleeve will stay in place. However, 90 degrees is the best holding power.
Sean
ROLLER DOLLY (A53843)
2008  BIG TEX 16' T/A TRASH TRAILER (A53843)
2008 BIG TEX 16'...
Harrell 3605 (A50123)
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
5TH WHEEL MOUNTING PLATES (A53843)
5TH WHEEL MOUNTING...
Advance SC750 28in Floor Scrubber (A53421)
Advance SC750 28in...
