Propeller Shaft Removal and Installation on a L2500DT
   / Propeller Shaft Removal and Installation on a L2500DT #1
theoldmanb
I have recently purchased a L2500DT and have a leaking seal where the propeller shaft enters the front sheel drive case. Presumably, the root of the problem is the oil seal. Has anybody out there replaced this seal, and if so, do you have any tips for the replacement including tips on the removal and installation of the propeller shaft?
   / Propeller Shaft Removal and Installation on a L2500DT #2
Depends where the shaft is located, on my JD it's just got 4 1/4 inch horse shoe brackets, should just drop down
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A51039)
3-Point Hitch Root...
1982 LeeBoy Motor Grader (A51039)
1982 LeeBoy Motor...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A51039)
2018 Rock Solid...
