joshuabardwell
Elite Member
I am running a gas range off a 20 lb propane tank. I've got a two stage regulator on the tank and have converted the stove's regulator, orifices, etc... Everything was working fine up until yesterday, when the stove began acting starved for fuel. The burners have small flames. The oven looks like only one side of the burner is on. Most tellingly, if I turn on a top burner and then turn on the oven, the top burner shrinks near to nothing.
When I was first testing this setup, I ran the stove on a nearly empty tank to ensure that the pressure would be adequate. It worked fine. The tanks I'm using are both full. Same issue on both tanks. The only thing I can think of that's changed is it was a little colder last night than the night before, and all my testing was done in the summer. Would a ten degree difference in ambient temperature make enough difference in the tanks' vapor pressure to cause this effect? The only other thing I can think is that the regulator or stove has malfunctioned, but that really seems unlikely. Nothing else changed between when it was working last night and now.
I really want to figure this out if possible. I have a bunch of people to cook for tomorrow. I limped through tonight, but it was slow and the oven didn't get hot enough to cook the food like it really should.
