hddnis
- Joined
- Aug 1, 2011
- Messages
- 215
- Location
- Not putting in, required or not
- Tractor
- If I want to leave it blank I will
Sensible Nick,
You may be an engineer, good for you, I'm sure you are a good one.
My first hand experience is running a snow and ice removal business. I make good money doing it.
We use diesel fired snow melters. We use propane fired torches to melt snow on some properties where chemical snow melters cannot be used. One account is a botanical garden and any chemicals must be specifically approved, ice melters are not approved due to potential damage to the soil. I don't fully agree, but they pay me to do it their way. The main point would be that their cost per square yard is the same as using chemical ice melters, so basically propane is not an outrageous idea.
We use and install diesel fired, propane fired, wood fired, natural gas fired, coal fired, electric fired and geo-thermal in ground ice and snow melting systems that heat the ground. This is very often less expensive, more proactive and better for the environment than Plow, Sand and Salt programs (PSS)
What we have found is that the traditional PSS is not always the best solution. For example the snow melters in many cases burn less diesel than trucking the snow away. We turn it into water and send it down the storm drain, where it will go anyway. Less polution, less congestion on the roads, fewer trucks for us to maintain.
So, we can agree to disagree I guess. For my part I'm going to do my best to help the OP make something that will work based on what I know and have built or bought myself. I know his idea may not seem to be the very best, but a lot of good things have come from what others thought to be silly. You can either encourage a hobby and learning and progress, or you can say it won't work, without running any numbers, with no first hand experience, based only on your gut feeling. Think about it.
Mr. HE
Mr. HE
