Propane powered ford - authentic?
   / Propane powered ford - authentic? #1
kquinton
I recently purchased a Ford Tractor from a auction. After researching the model # (b1123c) and serial number (c331057), I concluded this to be a 1972 Ford 2000, LCG, Live 540 PTO, 8 speed (if I am wrong let me know). However, the model number indicates gas tractor but this one has a propane driven engine. Is this tractor I bought a completely modified tractor (gas to propane), or partially modified (original propane to modern propane tank), or is there a problem with my ID plate? Also it was painted yellow like it was Industrial? Is this correct? Picture of tractor and ID plate are attached.
   / Propane powered ford - authentic? #2
11*2* designates gas.
looks like someone got handy ahd chopped the dash and top panel out.
propane versions were available. perhaps they used that machine as a shop tender and converted it?
not uncommon to see mix n match fords.
I have 2-3 rowcrops that are on gas now that started life on LP
Thank you so much. I figured as much but wanted to be sure.
   / Propane powered ford - authentic? #4
while i've not seen a 3 cyl propane.. I have seen plenty of 4 cyl jobs.. though the 3 cyl model id specs call out a possibility of it. I simply can't imagine a factor job was to chop out the dash cluster.. :)
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
Truck Bed (A53117)
Truck Bed (A53117)
2003 Pierce Spartan Pumper Fire Truck (A54814)
2003 Pierce...
SCAN FOR HAULING AND FINANCING INFORMATION (A52706)
SCAN FOR HAULING...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52705)
KNOW BEFORE YOU...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
