Propane or Electric back up?
/ Propane or Electric back up? #1
GT2
Athol ID.
Kubota L-35
I'm trying to explore the possibilitys for my wood and solar water, back up power.
2700 sf tight well insulated ranch style home in N Idaho. About 40,000 heat calc. Radiant in floor.
My two choices are propane ( $2.90 gal & rising ) and electric (.064 kwh & stable hydro ).
I have used several on line calculators and unless I have missed something electricity seems to be about 1/2 the cost?
I'm thinking of using a large instant hot water heater as a back up for the radiant.
I relies this will involve a large power supply infrastructure, but the up front cost of the unit is about half the cost of a propane unit.
Another variable is that I can help pay for electricity with solar and wind, I cannot however, make my own propane.
What am I missing?
Thanks, Tim
/ Propane or Electric back up? #2
I have a friend in Monroe NY that replaced his oil heat with coal. This winter he used 4 tons at $175/ton. Something to think about.
/ Propane or Electric back up? #3
GT2
Enjoy your super low electric rates and go with that. It wouldn't be the case in the midwest. Don't know what you can do with coal in your neck of the woods.
I backup with propane. Had to use it only over one weekend this winter. So far the wood boiler has handled about the same size home that you have.
/ Propane or Electric back up? #4
you may want to read the duty cycle on those instant hot water heaters. Not all of them are built the same.
May i ask why you are not looking at heat pumps if your electrical cost are so low.
And i am envious, we pay 32 cents a KWh
/ Propane or Electric back up? #5
32 cents! Ouch. We pay about 12 here in southwest Texas, it was 8 less than 6 months ago. Lots of talk about another increase.
Propane is about 2.60 per gallon. We have lots of gas production here. You might give a look to summer prices on propane and get a tank large enough to carry you through.
/ Propane or Electric back up? #6
You say this is a backup, but not under what conditions you expect to use it. If this is mitigate some sort of outage, you should make sure your backup is not vulnerable to the same issues as your primary. I.e., if your primary is solar, a single event, such as a large storm, could disrupt both your primary solar and your backup electricity (downed power lines).
Also, storage. Electricity is very difficult/expensive to store, so you're dependent on your electrical provider to keep a constant supply flowing to you and you quickly feel any changes in price. Propane is very easy to store and it stores indefinitely. You could buy a large tank full of propane tomorrow and it'll be there for you years from now, with no recurring costs to keep it on hand. You own it. Doesn't matter if the mideast melts down into total war and the cost of all energy quadruples overnight.
Keith
Keith
Good points Keith
"Back up" for me means I'm too lazy to go out and stoke the wood boiler:laughing:, or I,m not home and the wife couldn't be bothered. Also could be a bunch of cloudy days, so no help from the solar hot water.
I know electric/storage is expensive. That is not what I intend, other than short term. After that it would be gen power.
Point taken on the propane, however if the ME does melt and costs quad; as soon as that tank is empty it will mater!! ( applies to gen power too!).
Tim
/ Propane or Electric back up? #8
Use an electric heat pump water heater, it uses less than 1000W when running, mine runs fine on a generator.
You can put one inline with your solar heater.
AK, I'm not super informed on heat pumps. From what little I know I have been turned off by the complexity and the costs of such systems.
Tim
/ Propane or Electric back up? #10
You can see water heat pumps at Lowes, Home Depot or whatever big box retailer is in you area. Not to be smart but does a refridgerator or deep freezer turn you off due to the complexity? A house geothermal heat pump or a hot water heat pump is doing the same thing your fridge or freezer does. My geothermal has been serviced once in 13 years because the coil rusted out. My neighbors have replaced their heating systems at a similar age but I hope to get 30 years out of my system.
/ Propane or Electric back up? #11
i too live in north idaho...athol idaho to be exact. we have a wood fireplace for backup heat source. The primary heater is an electric heat pump with a gas back up (when outside temp is below 20F). Since our electric prices are only $0.06/KWH, electric heat pump seemed the best way to go. I also have a propane backup generator to assist if all else fails. were on a community well system, so i dont have to worry about powering up a well. It helps that im an electrical contractor, so i pre-wired my house for the backup generator. Alot of people up here do plan on using a generator, and i wire alot of houses with that in mind. Also keep in mind that a large instant hot water heater in the electric model takes alot of energy to run., ive hooked up some that need three (3) 60 AMP CIRCUITS TO OPERATE THEM.
Heat pump systems are not complicated, and work very efficiently down to say...+25 F, then either electric or gas backup kicks in raising the cost. I have a 4200 SF house, new construction, heavy on insulation. Not counting initial start up load, ive tested my heat pump while running and it only draws about 32 amps.....remember, a 2000 watt baseboard heater can draw 15-20 amps, and heat 1 room. im heating the entire house for this.
Now, usually when its super cold outside, im burning wood in the fireplace so it really doesnt matter. One further bonus of the heat pump system.....You get air conditioning for no additional cost of equipment. The equipment simply reverses flow. I do like A/C on some of those hot days in the summer. Now i dont have to leave windows open, and dont get a house full of dirt moving with the air.
My 50 Amp propane backup generator cant power up the heat pump, but my backup heat for the heat pump is propane. So my backup genset powers up the gas furnace, most of the lights, refer, freezer, microwave, master bath, entertainment system, and for some reason....my xmas lights. Im not sure why i did that..probably to piss off the neighbors when power fails and my xmas lights are on .:laughing: :D :D :thumbsup:
/ Propane or Electric back up? #12
If my water heater ever craps out, I will be looking at the hep-pump type as well.
But mine is an 85 gallon marathon. Lifetime warrenty and one of the mose efficent electric heaters, so I doubt it will be anytime soon.
But to answer the basic question you asked, propane is ~91,000BTU PER gallon. SO assuming 100% efficency, $2.90 will buy you 91,000BTU's.
At your super low rate of .064 per kwh (mine has been .08 for the last 5 years but just went up to .10:mad:), you can buy ~45000 watts of electricity for the same $2.90. And their is 3.41 BTU's in each watt.
SO...2.90 buys you either 91000BTU's with propane OR 153,000 BTU's of electric. AND since electric is easier to install, and you already have electricity obviously, it would be a no brainer.
Propane would require a tank, you would have to keep an eye on it so you dont run out, and plumbing it in is going to be more $$$ than an electric.
But keep in mind that the HP types are about 3x's more efficent than the electric resistance. So that would be like getting ~450,000BTU's for every $2.90. The only drawback I can see to them is that in the winter, they will cool the room their in unless you vent them to the outside. Kinda the same way a refridgerator puts out heat. But other than that, they are still more efficent and as another poster mentioned, they are not any different than a fridge or freezer.
/ Propane or Electric back up? #13
At your prices, electric is the way to go. Remember that the heat pump will make heat efficiently down to 0 deg or less. Problem is that it does not make enough heat at very low temps, so a supplement (backup) is needed. At anything but the lowest temps, the electric backup is not on continuously, but only cycles at add heat as needed.
paul
/ Propane or Electric back up? #14
Interesting your rates are so low. Are they still that low when you exceed so many KWH aka tiered rates? I cannot help but think that rates will go up on everything electricity especially if the demand for it continues to rise. Also, does 6 cents include transmission and distribution costs? Often time the more KWH you use, the higher the distribution and transmission rates. I can see where solar electricity will never be viable from an economical point of view where your at. Where I am, solar does pay for it self WHEN you include the Federal and State rebates.
PS, are you supplied with electric power by a private utility or a public utility?
/ Propane or Electric back up? #15
private utility....no tier is used. we run hydroelectric power here.....the cheepest way to go.no mater how much elect we use....6 cents per kwh
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63689)
2019 Cadillac XTS...
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2013 Ford Transit Connect Cargo Van (A61573)
2013 Ford Transit...
Rhino 7ft Blade (A63688)
Rhino 7ft Blade...
