PaulT
I planned to fry a turkey for Thanksgiving, but rather than buying one of those fryer kits you see everywhere for $70, I bought a 2-burner camp stove from Sams that I could also use for camping. The stove cost $100, and the pot I needed cost me another $40, but I can do 2 birds at once. After getting the stove home, I noticed that the burners are rated at 30,000 btu each. The better turkey fryers I saw claimed a BTU rating of 170,000. I even saw one rated at 200,000 btu! These burners LOOK just like mine. Basically, big cast Iron rings with 2 circles of holes. What is the difference between my burners and the fryer burners? It seems that it must be the regulator, since the BTU rating has to come from burning more fuel per/minute if both use propane. What am I missing? can I just buy a regulator with a higher flow and increase the BTU of the burner? Any help is appreciated. For the curious about why I need more BTUs while frying, read on...
Before frying the turkey, I did my research. I learned that I was to heat the oil to 375, slowly lower the turkey several times, covering more and more of the bird each time to drive out the water. After finally dropping it in all the way, the oil should be maintained at 350 degrees until finished, about 3 minutes per pound. If the oil temp drops below 340, then the bird will absorb the oil.
Once I but the bird into the 375 degree oil bath, the temp dropped to 270, and never got hotter than 285. The turkey was still done in the 3 minutes per pound time range, and it didn't taste greasy (except for the skin, which would have been nicer if it was crunchier - love that turkey "pork" rind!). Apparently I didn't have a hot enough burner to raise the oil/bird back to the recommended 350, nor keep it above the 340 mark. Hopefully I can just get a higher flow regulator and use it when I am frying big wet/cold things like turkeys or whole pigs (just kidding, but wouldn't that be great!).
PaulT
PaulT
