PROOF METER CABLE WHINNING SOUND WHEN COLD--OIL ANYTHING?
   / PROOF METER CABLE WHINNING SOUND WHEN COLD--OIL ANYTHING? #1
ROUNDBABY
CORNELIA, GA.
COMPACT FORD 1310
I GOT A FORD 1310 COMPACT TRACTOR AND FIXED MY PROOFMETER CABLE AND SAW THAT IT HAD FALLEN OUT OF ITS HOLE ON THE END OF CABLE JOINING THE GENERATR. I NOTICED A SQUARE NUT RIGHT ABOVE WHERE CABLE SCREWS IN LOOKED LIKE A FILL PLUG FOR SOMETHING. WOULD THIS BE FOR LUBRICATION OF THE PROOFMETER CABLE END AND GOVERNOR OR GENERATOR??MIGHT STOP WHINNING SOUND MAYBE?
   / PROOF METER CABLE WHINNING SOUND WHEN COLD--OIL ANYTHING? #2
Most cables of this type use a graphite lube. Go to your local auto parts store and tell them you need lube for a spedometer cable (same type cable).
Bill
THANKS FOR THE GRAPHITE IDEA--DO YOU KNOW WHAT THE CABLE IS SCREWED INTO THE BACK OF AND WHAT THE SMALL SQUARE NUT IS FOR? IT HAD A SMALL WIRE WRAPPED AROUND THIS NUT--LIKE IT HAD A TAG ON IT YEARS AGO--JUST ANOTHER CLUE. HOW DO YOU GET THE GRAPHITE INTO CABLE HOOKED ON HP--THANKS
   / PROOF METER CABLE WHINNING SOUND WHEN COLD--OIL ANYTHING? #4
Graphite is hydroscopic (attracts moisture). Graphite is good for steam and another hot stuff. Unless the lube contains rust prevention it will rust steel. I would check if there is a molly lube.
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
UNUSED TOPCAT ECSSSTG200 HYD STUMP GRINDER (A51248)
UNUSED TOPCAT...
TORO DINGO WALK BEHIND SKID STEER (A51246)
TORO DINGO WALK...
UNUSED RAYSKY RM87-96 MOBILE TOILET (A51248)
UNUSED RAYSKY...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
UNUSED BB500 DUSTLESS BLASTER (A51248)
UNUSED BB500...
