PROOF METER CABLE WHINNING SOUND WHEN COLD--OIL ANYTHING?
   / PROOF METER CABLE WHINNING SOUND WHEN COLD--OIL ANYTHING? #1
ROUNDBABY
CORNELIA, GA.
COMPACT FORD 1310
I GOT A FORD 1310 COMPACT TRACTOR AND FIXED MY PROOFMETER CABLE AND SAW THAT IT HAD FALLEN OUT OF ITS HOLE ON THE END OF CABLE JOINING THE GENERATR. I NOTICED A SQUARE NUT RIGHT ABOVE WHERE CABLE SCREWS IN LOOKED LIKE A FILL PLUG FOR SOMETHING. WOULD THIS BE FOR LUBRICATION OF THE PROOFMETER CABLE END AND GOVERNOR OR GENERATOR??MIGHT STOP WHINNING SOUND MAYBE?
   / PROOF METER CABLE WHINNING SOUND WHEN COLD--OIL ANYTHING? #2
Most cables of this type use a graphite lube. Go to your local auto parts store and tell them you need lube for a spedometer cable (same type cable).
Bill
THANKS FOR THE GRAPHITE IDEA--DO YOU KNOW WHAT THE CABLE IS SCREWED INTO THE BACK OF AND WHAT THE SMALL SQUARE NUT IS FOR? IT HAD A SMALL WIRE WRAPPED AROUND THIS NUT--LIKE IT HAD A TAG ON IT YEARS AGO--JUST ANOTHER CLUE. HOW DO YOU GET THE GRAPHITE INTO CABLE HOOKED ON HP--THANKS
   / PROOF METER CABLE WHINNING SOUND WHEN COLD--OIL ANYTHING? #4
Graphite is hydroscopic (attracts moisture). Graphite is good for steam and another hot stuff. Unless the lube contains rust prevention it will rust steel. I would check if there is a molly lube.
2020 Kubota SVL 75-2 Skid Steer (A51573)
2020 Kubota SVL...
2018 Ford Transit 250 Cargo Van (A51692)
2018 Ford Transit...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2000 Volvo VNL Truck, VIN # 4V4N21JF4YN250174 (A51572)
2000 Volvo VNL...
2017 SANY SY365C LC EXCAVATOR (A51246)
2017 SANY SY365C...
2021 Ram 1500 Bighorn (A53472)
2021 Ram 1500...
