Promise Made, Promise Kept
   / Promise Made, Promise Kept #21
I've got a 14" & 18" saws, & have had a few trees that once felled I had to cut& roll 360 degrees and still has a few inches in the center that was still attached & needed finished off with a hand saw. maples can grow pretty big around i these parts same with a few old slipperly elm & oaks...
Mark
   / Promise Made, Promise Kept #22
Spiker what you might consider is just buying a 20" bar with chain from Baileysonline you can get them for $15-$28 for the combination. That would help to keep from spinning the log. And a lot cheaper than buying a bigger saw.
   / Promise Made, Promise Kept #23
I've seen some huge oaks cut with 16 and 18 inch bars. I wouldn't try it but my granddad didn't mind. I don't know how they did it but they would cut down 4 ft. diameter trees with those little saws. Like someone else said, we were never cold.
   / Promise Made, Promise Kept #24
Them good ole boys back then that used misery whip saws and stood on spring boards could outwork me any day of the week I think. Cutting down big trees without chainsaws..Now that was hard work.
   / Promise Made, Promise Kept #25
I would have liked to have some of that log for lumber. I've cut trees down that were over 30+inches in diameter with a 16" bar, it's not a hard thing to do just takes a little more time. I figure if the ole timers could cut redwoods with an axe I got life easy :D
Don:
Have you ever tried turning the saw upside down when hand filing? Works good for some guys, lets you file both sides in the same direction.
Actually what I do is ...sit down, put the handle on the ground, put the bar up across my left leg...to file the other side. Hard on my pants, but works to a degree:)
Nice job. I was looking for Safety glasses and earplugs but what the heck. I agree about not needing to use big saws all of the time. I do most of my work with a 16" bar on a Husky. I can run that all day versus carrying around the bigger saws. I dropped 7 trees a couple of weeks ago all Doug firs from
90'-120' tall using the 16" Husky and 25" bar on the Stihl 046. They were 20"- 34" at the base. I have a Husky with a 36" bar when I want nice clean face cuts and back cuts for risky trees. My favorite saw is my Stihl 026 Pro.
I think you did good Sir.
I knew someone would tell on me........LOL.
Did ya notice anything else missing. (gonna tell on myself now)
Hard hat, chaps, boots.
only used apple in a smoker as far as I know but about a month ago we had a pig roast and threw some mesquite and oak (maybe??) on for some smoke flavor. I don't have much expirence in smoking meat but I know that the meat we have smoked was good.:drool:
Cherry can be used for smoking meat, but don't use cherry sticks for roasting hot dogs or anything.........they are supposed to be poisonous.
   / Promise Made, Promise Kept #29
Yeah I was just getting started but didn't want to seem like I was picking on you. :D I started cutting firewood with Chainsaws when I was 10. That is 40+ years ago now. I didn't start using safety glasses and ear plugs until I started doing more serious tree work about 10 years ago. Now I wear the helmet chaps glasses and ear plugs just about every time I am running the saw on the ground. Up in a tree I won't do it unless I have all of the head ear and eye protection on..
And that is exactly when your well formed hinge preformed as it should have. I'm proud of myself when I get a decent parallel hinge all the way across and I don't try to cut trees that are much bigger then my 18" saw bar. May be a wedge would have taken the waiting for the wind out of the game but it all ended as you planned.:drink::drink:
I was actually proud of myself for the way I cut it. But one other thing I've learned from experience, is never to remove the saw from the 'felling cut', unless the tree is falling(the bar acts as a stop in case the tree wants to go the wrong way).
Wedges would have worked great........just don't have any, LOL.
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2014 KALMAR 4X2 YARD DOG (A50854)
2014 KALMAR 4X2...
2011 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2011 FREIGHTLINER...
TANNKO  130BBL VAC TRAILER (A50854)
TANNKO 130BBL VAC...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A51039)
2004 Capacity Yard...
