Promise Made, Promise Kept
   / Promise Made, Promise Kept #11
I've got an MS250 with a 16"bar and have cut some large oak with it.Takes longer but if the chain is sharp the job isn't that bad.My neighabor gave me a large cherry and I took it to a local saw mill and had some nice boards made.I made several cabinets with some of them and have the rest of the boards stored in the barn.Eddie on a side note I see you still have that hog. russ
That old girl going to keep you busy..cutting,splitting,stacking..for couple days.
Glad all went well. :)
Tree was all cut up by 3 pm today, My son will be splitting some while I'm out on the road. The largest pieces will be done next wekend.
I was looking at the reasonably straight hinge you left on that tree. Just from that I figured that you know what you were doing. You had to shape that hinge from four different positions and that kind of work is way beyond me.
'Reasonably' , is a very good word. Closeup would tell a good story.
The 'felling cut', on the left side of the notch ended up being 1 inch below the notch(that's not a good thing). But as you described, it must be done from 4 directions, and can get quite difficult.
But the most fun part was............I needed the tree to fall in a little different direction than what the actual 'lean' was. After I finished my cutting, the tree just stood there, with about 1.5 inches of hinge holding it. A wind gust took it on over for me:thumbsup:
   / Promise Made, Promise Kept #14
I'm on my second Stihl 026. Its a fine saw. My first one is probably still running great for whoever stole it from my shed!
BOB
   / Promise Made, Promise Kept #15
To bad it's going for firewood. Looks like some beautiful furniture wood from what I can see. Although we burn wood also and I'm sure we have burned some beautiful wood too. We tend to be parshal to Black Locust though because it will burn just as well green.
   / Promise Made, Promise Kept #16
I know apple is a good wood to use in a smoker, isn't cherry also supposed to be good? I've used hickory, mesquite, pecan, and oak, but never apple or cherry.
   / Promise Made, Promise Kept #17
only used apple in a smoker as far as I know but about a month ago we had a pig roast and threw some mesquite and oak (maybe??) on for some smoke flavor. I don't have much expirence in smoking meat but I know that the meat we have smoked was good.:drool:
   / Promise Made, Promise Kept #18
Although I should add.......The cuts aren't as straight as they appear.........I have a hard time filing both sides the same amount.
Don:
Have you ever tried turning the saw upside down when hand filing? Works good for some guys, lets you file both sides in the same direction.
   / Promise Made, Promise Kept #19
Nice job. I was looking for Safety glasses and earplugs but what the heck. I agree about not needing to use big saws all of the time. I do most of my work with a 16" bar on a Husky. I can run that all day versus carrying around the bigger saws. I dropped 7 trees a couple of weeks ago all Doug firs from
90'-120' tall using the 16" Husky and 25" bar on the Stihl 046. They were 20"- 34" at the base. I have a Husky with a 36" bar when I want nice clean face cuts and back cuts for risky trees. My favorite saw is my Stihl 026 Pro.
I think you did good Sir.
   / Promise Made, Promise Kept #20
And that is exactly when your well formed hinge preformed as it should have. I'm proud of myself when I get a decent parallel hinge all the way across and I don't try to cut trees that are much bigger then my 18" saw bar. May be a wedge would have taken the waiting for the wind out of the game but it all ended as you planned.:drink::drink:
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
2021 Case Trident 5550 Spreader (A51039)
2021 Case Trident...
2007 PETERBILT PB335 LUBE TRUCK (A51243)
2007 PETERBILT...
2017 Claas Jaguar 860 Forage Harvester (A51039)
2017 Claas Jaguar...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2023 John Deere 8R410 MFWD Tractor (A51039)
2023 John Deere...
