Project Update -- The Dozer Arrives
   / Project Update -- The Dozer Arrives #11
Cat Dozers used to have what was called " power shift " . It was auto/hydro, had three forward and one reverse all manually operated with the left hand. They had a throttle and foot operated decelerator with two hand operated steering clutches as well as foot operated brakes. The blade controls were operated with the right hand. This is what my feeble memory recalls.
Egon
   / Project Update -- The Dozer Arrives #12
Sounds like the Cat loaders I use to operate...
Forward and reverse shifter on the column with 3 forward and reverse gears activated by twisting the shifter. Plus a foot activated accelerator and brake. A very efficient setup!
   / Project Update -- The Dozer Arrives #14
Not that big... It was a 930... The 920 was also setup the same way...
   / Project Update -- The Dozer Arrives #15
Too bad you have to miss out by going to work. Can't tell from the pictures, is this contractor doing the whole job (cleanup and regrade) or just the parts you didn't want to do?
Mainly, I'm just having him do the parts that I either couldn't do with the 4400 or didn't seem "feasible" for it. Lots of small locust and hedge trees (and some big ones) and I figured by the time I paid to have all the flats fixed, it would be cheaper to get someone in to do it right. I really want to do a lot of it myself. It was one of the reasons I bought the tractor. While I'm semi-retired (at least until recently), most of the work I do is desk/computer work and I really wanted something to enjoy the outdoors with. Once he gets done with his part, what I want it to ultimately look like may be a two, or more, year project but it gives me an "excuse" to get away from the desk and spend time outdoors.
Hoss
   / Project Update -- The Dozer Arrives #17
What's the latest on this project? Should be providing ample seat time with the reasonably warm weather everyone's been having.
Not much has been going on with it. The dozer guy took his toys home and told me to call him when I got the brush piles burnt up. Been a pretty slow process gettin' that done. Early on, the wood was so green that even after burning up over 80 gallons of diesel, there was still more than half the piles left. Then, around the first of February, the wind started blowing. Apparently, even with rain, snow, ice and ground so wet that you could sink a foot into it, the grass on top was bone dry. Where I live, each day you want to burn you have to call the fire chief and get a burn permit (verbal O.K.). Yesterday, I got the first permit he had authorized since the 9th of February. Only took a wind speed of 0-3 mph to get the go-ahead. He had turned me down previously at 7 mph as he had already spent the morning fighting grass fires. Anyway, finally got them burned up, as much as they're going to burn, yesterday. Now I have too get the dozer guy back to make some more brush piles and bury the root balls from what has burnt. Only problem is, the ground is saturated with water. Every place he left a track rut or pushed out a tree last time has standing water in it and we haven't had any rain in 10 days. Hopefully, the wind will keep blowin' now and dry things out before it rains again.
And that's the name of that tune./w3tcompact/icons/smile.gif
Hoss
   / Project Update -- The Dozer Arrives #19
HOSS: same here, even tho it has been a mild winter will not be able to get really much done till late april AFTER I GET BACK FROM VACATION.. sure would have been nice to get out there today, but everything is mud and will be for a while yet. keep us posted.
   / Project Update -- The Dozer Arrives #20
First... <font color=blue>over 80 gallons of diesel</font color=blue>
And then... <font color=blue>the ground is saturated with water</font color=blue>
Hoss, sure that is water in the ground??? /w3tcompact/icons/eyes.gif
Sorry, couldn't resist... /w3tcompact/icons/smile.gif
2016 GENIE Z80/60 TELESCOPIC BOOM LIFT (A52709)
2016 GENIE Z80/60...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
Kubota KX61-2 (A55272)
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A56435)
LIKE NEW 2023...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
