Project All-Klaw (root grapple)
   / Project All-Klaw (root grapple) #1
Trucker1
Western Maine
John Deere 4510
I am building a root grapple from two halves of an old Prentice log loader "pulp bucket" that was owned by my Grandfather Allen--(the "All" in my project name).
Each one measures 20" wide.
With each piece being 20" wide, I welded a 19" spacer in between the two pieces.
This will give me my base for a 60" wide grapple.
   / Project All-Klaw (root grapple) #3
That certainly looks like it will be real rugged! I'm anxious to see the rest of the build.
Corm
I have cut the two inner ears off by 4" so that I can weld in 4" square tubing across the top. This square tubing will give me a strong surface to weld my mounts, plus tie it all together.
I have cut off the large 1.5" round tie rods that you can see in top of the previous pic. I will be reusing these later for guards in the center.
I have welded in the 4" square tube, then welded in 4" C-channel for my JD quick attach mounts. I also plasma cut the mounts for the grapple from 1/2" steel and drilled out 1" holes for the pivots. I spaced them for a 30" wide grapple.
I was afraid that 30" would be too wide, but everyone started ordering Markham grapples that wide about that same time, so I figured I had made a good decision.
I hand drew the pattern for my grapple on cardboard, transferred to 1/8" hardboard for plasma cutting.
(Apologies to all who designed this first, if it ain't broke, why fix it?:rolleyes:)
I then plasma cut my design from 1/2" steel.
   / Project All-Klaw (root grapple) #7
Are you going to add any tines to the bottom to dig under roots?
Mike058--Not really. There'll be a tine in the center where the spacer was added. The 1/2" plate at the ends of tines will be removed as marked on pic.
That will give me 7 tines altogether.
   / Project All-Klaw (root grapple) #9
Very nice work so far.
I'll say one thing, you will definitely have a heavy duty grapple there. Have you determined how much it will weigh yet? Not that it should be any problem for your JD though.
I like the beef! Keep the pictures coming.
   / Project All-Klaw (root grapple) #10
Gotcha. Didn't realize those plates on the ends were coming off. This is a great way to recycle old steel.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
LEINBACH 1R CULTIVATOR (A52708)
LEINBACH 1R...
PALLET OF MISC PARTS (A52708)
PALLET OF MISC...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
KING KUTTER SCOOP PAN (A52708)
KING KUTTER SCOOP...
