Backhoe Problenm with removing backhoe on Kubota L48
   / Problenm with removing backhoe on Kubota L48 #1
RRitchie56
Kubota L48
Backhoe has been on tractor for long time. Having problems getting it off. Any suggestions on how to get it off. The levers on the backhoe will not move once the clips are pulled out.
   / Problenm with removing backhoe on Kubota L48 #2
There is a similar recent thread involving an L35. Patience and continual saturation with penetrating lube were the recommendations there and probably also for your L48. The consequences of years of neglect won't disappear overnight, unfortunately. It only makes it worse that it's hard to get at the mounts when the BH is on the tractor.
   / Problenm with removing backhoe on Kubota L48 #3
RRitchie56, I own a Kubota L35. When removing the backhoe, I stretch the hoe all the way out, then lift the back of the tractor with the hoe. Once the hoe is supporting the weight of the tractor, the release levers move easily. Ditto when installing the hoe. When removing the hoe for the first time (I don't think it had been removed for years when I bought it), I ended up bouncing the back of the tractor with the hoe to get things freed up, along with a couple weeks of regular penetrant soak.
8' SINGLE AXLE TRAILER (A52708)
8' SINGLE AXLE...
1325 (A58374)
1325 (A58374)
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
2022 BOBCAT T740 SKID STEER (A52709)
2022 BOBCAT T740...
