Problems with my tym tractor
   / Problems with my tym tractor #1
Spacegunjohn1340
Tym t554
First time I put the tractor in 4wheel drive made a right turn the left axle came out and the tractor went down on the left side the regen system will not work 3 month ago the right side real axle was making noise they replaced the bearing and seal , I picked it up after 8 weeks . Now it’s doing the same thing only 5 hrs . I called to tell them no one called me I was mowing grass when I was driving it back to the barn the right front axle came out oil all over the grass now they have to come and get it , there is only 660 hrs and there has been a few more problems I have to see if Can lemon law it
   / Problems with my tym tractor #2
That is quite a list of issues. What model and what are your main uses for the tractor?
   / Problems with my tym tractor #3
Wow,
Ouch is all I can say. Not to make things worse, but there is no "lemon law" for tractors.
Can you find a different dealer, or is that the only one in your area?
I would be tempted to contact corporate TYM and see if that helped.
660 hours, how old is it? Out of power train warranty?
   / Problems with my tym tractor #4
OP, you need to consider breaking down your issues. You say the first time you put it in 4wd you had problems, but later say it has 660 hours. Did you buy it used?
660 hours is about 6 years or so with typical hobby use.
It would also help if you gave a general idea of where in the world you are. People may be able to recommend other dealers or mechanics.
   / Problems with my tym tractor #5
Yes, being more forthcoming with your information would help.
It's pretty "thin", so far.
T554 shuttle shift 80 percent is mowing 60 acres just grass not hay o have a 5 foot bush hog only used 2 times grapple I use to remove piles it tree branches I don’t do any digging. And I help my Nabor to load hay rolls after he rolls it the tractor is barn kept I have heard there is problems with the front end
   / Problems with my tym tractor #7
How big are these round bales? Do you have anything on the 3pt hitch for counter balance?
I have not heard of all this issues on the TYMs.
Sorry the first Time I put the tractor. In 4 wheel drive it had 367 hrs I was mowing by my pond and I thought I would put it in 4 wheel drive because it soft by the pond when I made a right the left front axle came out . So at 660 hrs the same thing happened on the right side and this time it was not on 4 wheel drive I purchased it new it takes me 17 hrs to cut my grass 60 acres with a 6 foot finish mower I live in Florida I do not do any heavy work a little bush hogging and I help my Nabor load hay rolls
About a thousand pounds tires are filled the tractor has no problem with the hay now the tractor 670 hrs the dealer picked it up today the oil leak they fixed at the rear wheel is leaking again it was fixed 1 month ago
Oh and when I seen the leak again I was driving the tractor to the barn and that’s when the l/ f axle broke I couldn’t move the tractor
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A51039)
2022 MAXXD BD14...
(INOP) VOLVO L70H WHEEL LOADER (A50459)
(INOP) VOLVO L70H...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2000 INTERNATIONAL 4700 (INOPERABLE) (A50854)
2000 INTERNATIONAL...
John Deere A Tractor (A50514)
John Deere A...
