Problems with my 2005 TZ24D
   / Problems with my 2005 TZ24D #1
Terry Hentges
Spokane, WA
New Holland TZ24D, Ford 9N restored, Case 310 super condition, cub cadet 1873 mower
I need some photos of under the hood to put it back together.
I had an electrical problem and still do, the glow plugs are not getting power to them? Anyways I tore this thing apart and can't get things together right. Any idea how to check power to the glow plugs?
A wiring diagram would be really sweet if someone has one.
The local dealer I have is totally worthless, sells NH on the side but is a Kubota dealer and mechanic 1st.
I have had a lot of problems with this unit. I also have a major leak in the hydro static but cannot find where it is coming from, nor could the dealer help when I took it to them. This thing only has 75 hours on it and I have had it since it was new! I have been pretty disappointed so this winter I tore it apart and I am trying to fix stuff I have no idea about. But I do have the lights working again! There is a horn button on the dash but I honesty cannot find the horn!!!
Thanks
Rick B. you are right but $450.00 for the manuals? I thought what the heck can't be that tough. Should have took photos to! I rebuild vettes and have some great old tractors that I have totally tore apart, I didn;t think this little thing would be that complicated. Helped a buddy with a newer 30 hp JD and it was pretty straight forward.
Rick B. you are right but $450.00 for the manuals? I thought what the heck can't be that tough. Should have took photos to! I rebuild vettes and have some great old tractors that I have totally tore apart, I didn;t think this little thing would be that complicated. Helped a buddy with a newer 30 hp JD and it was pretty straight forward.:D
   / Problems with my 2005 TZ24D #5
The CD version is under $300. That's just over a half day of shop time at most dealerships.
   / Problems with my 2005 TZ24D #6
Terry,
I have a service manual for my TC24DA. It should basically be the same in terms of wiring, etc. Let me see if I can find something out of the book that I can send you to help you out. Also I could take some pics of under the hood....what are you wanting to see specifically?
BTW, check EBAY for the manuals. I bought a complete set (Factory New Holland) sealed in plastic with the binder for $199.
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
1999 Ford LA-9000 Aeromax Godwin Steel Dump Truck (A52384)
1999 Ford LA-9000...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
