Problems with MMM Lowering
   / Problems with MMM Lowering #1
dlockh4258
Lexington Kentucky
Kubota B2910
Today is the first day I have got to use my new Kubota B2910. I have a 72" MMM. The tractor and mower performed great today except for one thing. For the first 3 hours the MMM raised and lowered very well. All of a sudden the mower would raise fine but when I tried to lower it, it would not go down. I played with it a little and finallywhen I would twist the knob that adjusts the speed of the raising and lowering toward the closed position, it would then lower. Is this normal? I had the adjustment set to lower and raise slowly. But all of a sudden, it will not lower unless I twist the knob to close and make it fast. Could someone help me out with this? Thanks
   / Problems with MMM Lowering #2
David
I have the same tractor. I have never had this problem.
Turning the knob Counterclockwise makes 3PH drop faster. Turning it Clockwise will slow it down. If turned full Clockwise you will shut the system off. You may have the adjustment very close to the lock position.
Turning the knob should not affect raise speed.
All that is the lower circuit is a check valve and flow control (knob).
There could be something caught in the linkage that makes position control work. This linkage is on the right side of 3PH right lift arm.
Hope this helps?
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
