Problems with cables to rear remotes
/ Problems with cables to rear remotes #1
jcummins
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
Over time the operation of the rear remotes has been getting rougher and rougher to work. This evening, I took some of the plastic off, and disconnected both ends of the cables. Found the problem is with the cables, not a bind on either end.
SO...how can I lube these, or can I? I stopped short of removing them, since getting to the nuts holding the cables is down in there....and on the rear remotes I've got a diverter valve that is a bit in the way. But, because of other issues I've had, I have had the rear fender off, and it exposes a lot of this. BUT before I do that, want to know if there is a way to lube these without taking them off, and if I do get them off, how to lube them.
This is on a M7040.
/ Problems with cables to rear remotes #2
I think that they are disposable with age/use. I have a friend that is replacing his loader cables (M7040 also). Lubricating, if you can, might just attract dust and .....
This is just a guess on your (and my) tractors JC but I do know that other "control cables", on other equipment is just a service item that needs to be replaced periodically, dust caps crack, liners wear, etc. I don't know the parts price, but all of them, loader & remotes look like no fun to replace.:mad:
/ Problems with cables to rear remotes #3
Dry lube like silicon or graphite doesn't attract dirt.
Small things that flex a lot are prone to wearing out though.
/ Problems with cables to rear remotes #7
Let us know how it works out. I'm sure many of us will face this eventually.
I will. Have order that cable luber thingajigy.
The cable thingy did not work, cable to big. It's made for motorcycle/ arv type cables. I had to modify it to even get the cable into it, should have sent back.
I rehooked everything, got mowing i need to do. I'm going to have to take that right rear fender off, and take the cables out to see if i can geavity lube them. They have definite roughness to them. I'll revisit this later in a month or so.
2022 EZ-GO ELITE...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
1057 (A63291)
1057 (A63291)
Pemberton Inc Komatsu Grapple Bucket (A64194)
Pemberton Inc...
KOMATSU PC88MR-11 EXCAVATOR (A64279)
KOMATSU PC88MR-11...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
