jcummins
Veteran Member
- Joined
- Jan 14, 2007
- Messages
- 1,637
- Location
- Creal Springs, IL
- Tractor
- Kubota M7040, F3680, Mule Pro Fxt
Over time the operation of the rear remotes has been getting rougher and rougher to work. This evening, I took some of the plastic off, and disconnected both ends of the cables. Found the problem is with the cables, not a bind on either end.
SO...how can I lube these, or can I? I stopped short of removing them, since getting to the nuts holding the cables is down in there....and on the rear remotes I've got a diverter valve that is a bit in the way. But, because of other issues I've had, I have had the rear fender off, and it exposes a lot of this. BUT before I do that, want to know if there is a way to lube these without taking them off, and if I do get them off, how to lube them.
This is on a M7040.
This is on a M7040.
