Problems getting DR Mower to start
/ Problems getting DR Mower to start #1
Pat in Olga
Olga, Wa
DR Mower
Hey Folks,
I have a DR Mower that is roughly 10-12 yrs old I recently replaced the 3 post solenoid, Starter, battery and 30 amp fuse able link and the thing still won稚 turn over. I took a test light checked to make sure I was getting the proper power from battery to solenoid I get power from the battery to the positive battery cable side on the solenoid but get nothing from the starter cable side of solenoid. I get no power on the top post ether. I ran a jumper wire from the battery to the solenoid and the starter will engage. I took the new battery, solenoid, starter and ignition switch into Napa where they tested all items and found nothing wrong with them. I知 lost as I致e been working on trying to get this thing running for over a month now on my days off. Anyone have any ideas.
Thanks,
Pat
/ Problems getting DR Mower to start #2
Welcome to TBN. Usually if you cann,t get a machine to turn crank, and the battery and connections are good, the problem is that one or several of the safety switches are open. Do you have a wiring diagram for your mower ? Do you have a meter or test light that will help in your search for an open safety switch ?
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
Landhonor 3Pt Potato Harvester (A66285)
Landhonor 3Pt...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
Used 20' Container (A62679)
Used 20' Container...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
