Problems fitting King Cutter Subsoiler combo on Kubota BX2230
   / Problems fitting King Cutter Subsoiler combo on Kubota BX2230 #1
bigbadinpittsburgh
I just bought a King Cutter Sub Soiler Combo for by BX2230. I can’t seem to get the Top Link to fit and have clearance to travel. Has any else had this problem?
   / Problems fitting King Cutter Subsoiler combo on Kubota BX2230 #2
I had to pry apart the top link fitting on the subsoiler to get it to fit on the 3pt on my Kubota B7510HST. Used a large chisel and sledge hammer together with some 1/4" thick steel shims to get enough clearance for the top line to work OK.
   / Problems fitting King Cutter Subsoiler combo on Kubota BX2230 #3
I had the same trouble with mine on my TC18. I pryed it apart and made a spreader out of 3/4" cold roll to keep it apart.
   / Problems fitting King Cutter Subsoiler combo on Kubota BX2230 #4
Same here, got mine 2 weeks ago. I took a splitting wegde/ bar of steel and a 4lbs sledge, hit it a couple times until it got just enough clearance...you dont' want to spread it too much or the top-link pin will bust your chops trying to silde thru smoothly.
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52748)
NEW 2025 Load...
2022 Mack MD Danco 12R22 22FT Rollback Truck (A50323)
2022 Mack MD Danco...
2019 Dodge Journey GT SUV (A50324)
2019 Dodge Journey...
New Holland 276 Square Baler (A50774)
New Holland 276...
