Before disconnecting hydraulic lines I make sure there is no tension in the implement. For instance a bucket, with engine off, place the joystick in all possible positions to settle the implement fully. Then I disconnect the QD's. Then I reconnect them again so that they Puke out a bit of fluid.. I believe this results in a deficit of fluid in the lines. Then when you hook back up they hook up easier. Also parking your implements in the sun after taking them off is not a good idea. Fluid heats up and expands. This seems to work for me, I don't have any problems any more. Years ago I used to struggle.
