Loader Problems attaching Kubota front end loader
   / Problems attaching Kubota front end loader
Thanks for the suggestions. I let a little fluid out of the loader and connections went right on.
   / Problems attaching Kubota front end loader #12
Glad to see that you got it to work. The first time I took my FEL off and then tried to put it back on I had the same issue. Apparently when the FEL sits there the hoses build up just enough pressure to keep you from being able to push the lines on sometimes. I found it’s mainly during warmer weather, but have had it happen to me a couple of times during cold weather.
After loosening the connections many times and bleeding it that way I started taking a 3/8" bolt with a smooth bottom, placing it inside the connection with a rag blocking any spray that might come out. And I tap it a couple of times with a hammer. This relieves the pressure and I stopped having to take the connections loose (BIG PAIN IN THE ARS).
Best of luck, Mark
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2015 Cheverolet Tahoe SUV (A55853)
2015 Cheverolet...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
2005 EAST 45' WALKING FLOOR TRAILER (A57192)
2005 EAST 45'...
UNUSED SDLANCH SDLE20 MINI EXCVAVATOR (A57192)
UNUSED SDLANCH...
INGERSOLL RAND T30 AIR COMPRESSOR (A57192)
INGERSOLL RAND T30...
