problem
/ problem #2
Does yuor power steering work? ( do you have power steering? )
what tractor is this on?
Loader?
Soundguy
/ problem #3
2004 Jinma 224 with loader(it is in his profile)
IF the loader and power steering are working, then you have flow from the pump. I think if it was an "O" ring, it would at least try and lift the arms without an impliment, but it wouldn't stay up if any weight was applied to the arms. What is the status of the 3PH speed control valve located in front of the seat? Is it fully clockwise(closed) or fully counterclockwise(open)? On some of the Jinmas, that valve knob has two functions.
1. Regulates downward speed of a heavy 3PH impliment.
2. When fully closed the valve restricts the flow into the 3PH cylinder completely and sends the pressure instead to a rear remote port to allow the control of a remote single acting cylinder such as in a dump trailer. With the valve knob closed, the 3PH arms won't move.
/ problem #4
If your steering and loader is working you will prob. need to rebuild the 3-point o-ring kit.I have also seen a few lift valves go out.First make sure you have flow from the pump.Installing the 3-point O-ring kit is not a real hard job,we sell a rebuild kit.
Tommy
Affordable Tractor Sales
/ problem #5
:confused: Would this also be the same type of repair if it lifts but slowly lowers it self? Just another problem I have to deal with.****James
/ problem #6
James
Is it the same type tractor? If it is a Jinma 200 series, you can probably quite easilly eliminate if it is the "O" rings or the loader control valve. That speed reg valve is located between the loader control valve and the cylinder. If you raise the 3PH then close the speed reg valve all the way, you will trap the fluid in the cylinder. If it still leaks down, then most likley you have an "O" ring problem as the fluid is most likley leaking past the piston seal/o-ring. If the 3PH stays put, then the "O" rings/piston seal are OK and the problem is a leaking control valve or the 3PH overload safety(protects the structure when you bounce a heavy impliment by venting cylinder fluid back to the resovoir).
This test is best done with a lighter or fairly easilly jacked impliment as when you screw that speed reg valve closed(clockwise) with an impliment in the air, you may have trouble opening the speed regulator valve back up till you jack up the impliment. The fluid flows upward past the valve seat and into the cylinder. With a load on it and the valve closed, the hydraulic pressure holding the load in the air is on top of the seat and you need to unscrew the valve against the pressure and this can be difficult, even will well lubricated threads. By jacking up the impliment with a floor jack, you are removing the hydraulic pressure from on top of that valve and it should then unscrew easilly.
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
2001 T/A Enclosed Trailer (A61569)
2001 T/A Enclosed...
2007 Volvo VNL Truck Tractor (A63118)
2007 Volvo VNL...
2007 INTERNATIONAL 9200i 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2007 INTERNATIONAL...
2016 Ford F-450 Utility Flatbed Dump Truck (A61568)
2016 Ford F-450...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63118)
2021 Takeuchi...
