Problem with rear remote on Branson 2400
   / Problem with rear remote on Branson 2400 #1
travlitt
Platinum Member
Texas
8050C Branson, Branson 2400, 8N Ford, Round Fender John Deere 110, 3 60" ZTR mowers, a bunch of ride on mowers, 8' Brush hog , 15' Bat wing
I had the dealer to install a remote service valve on my Branson 2400. It was to be used to operate the hydraulic third link. It worked for about 1 day. Now it will does not work. Now when I try to extend or retract the the cylinder ram, it causes the relief to operate.
What would cause this?
   / Problem with rear remote on Branson 2400 #2
It came unpluged
   / Problem with rear remote on Branson 2400 #3
One of your cyl hoses is not connected correctly.
Reset the QD's if used.
JJ
I disconnected the cylinder and connected the work ports together with a bypass hose. Still does the same thing, could it be a bad valve?
   / Problem with rear remote on Branson 2400 #5
Did you couple with the QD's or a union.
If you used the QWD, you may still have QD problem.
If you used a union to couple the hoses together, the fluid is supposed to go in one port and out the other port. If the relief activates in that situation, something is blocking the flow.
   / Problem with rear remote on Branson 2400 #6
Remove the cyl from the remote valve and place the hose in a bucket and see if there is equal flow from both work ports hoses.
vergenes (A50657)
vergenes (A50657)
Caterpillar Front Glass (A50854)
Caterpillar Front...
PALLET OF AIR CHISELS (A50854)
PALLET OF AIR...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
John Deere Quick Attach Pallet Forks (A50514)
John Deere Quick...
2012 KENWORTH T400 TANDEM AXLE 24FT REEFER BOX (A51222)
2012 KENWORTH T400...
