Problem with rear remote on Branson 2400
   / Problem with rear remote on Branson 2400 #1
travlitt
Platinum Member
Texas
8050C Branson, Branson 2400, 8N Ford, Round Fender John Deere 110, 3 60" ZTR mowers, a bunch of ride on mowers, 8' Brush hog , 15' Bat wing
I had the dealer to install a remote service valve on my Branson 2400. It was to be used to operate the hydraulic third link. It worked for about 1 day. Now it will does not work. Now when I try to extend or retract the the cylinder ram, it causes the relief to operate.
What would cause this?
   / Problem with rear remote on Branson 2400 #2
It came unpluged
   / Problem with rear remote on Branson 2400 #3
One of your cyl hoses is not connected correctly.
Reset the QD's if used.
JJ
I disconnected the cylinder and connected the work ports together with a bypass hose. Still does the same thing, could it be a bad valve?
   / Problem with rear remote on Branson 2400 #5
Did you couple with the QD's or a union.
If you used the QWD, you may still have QD problem.
If you used a union to couple the hoses together, the fluid is supposed to go in one port and out the other port. If the relief activates in that situation, something is blocking the flow.
   / Problem with rear remote on Branson 2400 #6
Remove the cyl from the remote valve and place the hose in a bucket and see if there is equal flow from both work ports hoses.
Hilti TE 2000-AVR Electric Jack Hammer (A49461)
Hilti TE 2000-AVR...
(3) VACUUM PUMP TANKS (A50854)
(3) VACUUM PUMP...
2020 JLG 1732 16,755lb 4x4 High-Capacity Rough Terrain Telehandler (A49461)
2020 JLG 1732...
2017 Nissan Murano SUV (A50324)
2017 Nissan Murano...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
