Problem with PTO engagement on Jinma 224
   / Problem with PTO engagement on Jinma 224 #1
jinmaman
Hello, I own a Jinma 224. My PTO does not want to engage. I used to leave the PTO engaged and leave the PTO speed select in neutral or 540 if I wanted it engage or disengage it. I recently played with the engagement lever for the PTO and the arm felt stiff and like it wasn’t actually moving properly (sloppy). I tried adjusting the length of the bolt on the rod that slides in and out in the tractor that is actuated by the cam on the engagement lever with no luck. The problem started after I played with the PTO engagement lever. I got it to disengage & engage a few times and then just stopped working. Now the arm is all stripped and the bent where it threads in. I figure something is not working internally. I don’t suspect the clutch but who knows. Anything I can do before I start major disassembly? Any hints/suggestions in the whole disassembly process?
   / Problem with PTO engagement on Jinma 224 #2
Sounds like the shift lump has broken or fell out,It's not a real big job to remove the hydraulic lift box it's just heavy,That will give you access to the area that the spline sleeve and shift lump is in.We keep the parts and will help you over the phone if needed.Just let us know
Tommy
Affordable Tractor Sales
Bellville,Texas
Thanks for the quick reply, I going to take a look at it tonight. Just to make sure we are talking about the same thing, the problem I am referring to is the lever arm that engages and disengages the PTO, not the speed selector lever (1000, Neutral, 540).
   / Problem with PTO engagement on Jinma 224 #5
Yes, picture 5 and the white asterisk may be your problem area.
Ronald
Ranch Hand Supply
   / Problem with PTO engagement on Jinma 224 #6
Ronald
Ranch Hand Supply
Ronald
Your the man, you do those pic's, its fantastic. Thanks for taking the time and effort to post those pic's to help people.
Just wanted to jump in there and say that.
   / Problem with PTO engagement on Jinma 224 #7
As someone who recently removed the hydraulic sump, let me STRONGLY suggest you get an engine hoist to help with this. I almost broke my back getting mine off my 454LE, was impossible to get back on without a hoist. That thing is heavy!
http://www.tractorbynet.com/forums/showthread.php?t=75730
Ronald/Ranch_Hand_Supply, Killer pictures! Don't know what we would do if it wasn't for guys like you and Tommy (@ affordable) on here.
Good luck Jinmaman.
Eddie
   / Problem with PTO engagement on Jinma 224 #8
Good luck Jinmaman.
Eddie
Ditto on the hats off to Ronald(Ranch Hand Supply) and Tommy (Tommy's Affordable Tractor). These guys deserve all our thanks for their help.
These guys are tops.
Harry
16FT Flatbed Trailer (A51573)
16FT Flatbed...
John Deere 4045D (A50120)
John Deere 4045D...
2014 Ford F-250 Extended Cab Knapheide Service Truck (A50323)
2014 Ford F-250...
2012 Ram 3500 Crew Cab Mason Dump Truck (A50323)
2012 Ram 3500 Crew...
43021 (A51691)
43021 (A51691)
40' Sea Container (A50774)
40' Sea Container...
