Problem with my Moldbord Plow
   / Problem with my Moldbord Plow #11
Yoour hitch style that was o nthe plow is called a sleeve hitck look in a Norther cataloague for Lawn and garden tractor Implements. Its gonnat neead the 3 point set up and the front like a Ferguson plow.
   / Problem with my Moldbord Plow #12
You have Brinley sleeve hitch plow made for a garden tractor. The sleeve hitch works differently than your 3 pt. The sleeve hitch pivots up and down from a fixed point, the 3pt is basically a paralellogram and lifts straight up. The sleeve hitch cannot tilt side to side, the 3pt arms can be pushed up independently. That's what is letting the plow roll sideways and bend your top link.
The "Beam" is far too weak for your BX, you don't need the screw adjuster, and the plow is too far rearward. You need to scrap the red portions of the plow and build your own frame from the plow (black vertical bar) forward. The frame should be rigid side to side. (The "A Frame" as you referred to it.) Also, you will likely bend the black bar going down to the plow itself unless you replace it or reinforce it considerably. Stop by the local implement dealer and see how the 3 pt plows are made. It's simpler than it sounds but you'll need heavier metal than you might think.
It will work great when you get it finished.
   / Problem with my Moldbord Plow #13
BXpanded you said exactly what I couldnt get out of my feeble brain lol. That attaches like my Farmall Cub and A plow does sorta like a mule plow to. They attach to the a lower mid mount drawbar with a pivot and the rear lift raises and lowers the plow.
You could do the same with the little plow since the pivots were intact make and adapter to bolt it to the drawbar on the tractor and use the lift arms with a cheapy lift arm drawbar attached to the top of the plow beam that way it would work like the old Brinley lift I had on and old LG tractor once. That way the plows angle could be adjusted like it as ment to from the factory.
   / Problem with my Moldbord Plow #14
I've been looking at the pics of your plow, and I can't see how you hooked the sleeve hitch on the plow to the mount you made that hooks to your lift arms. That needs to be a solid mount that doesn't swivel. Looking at the rear shots of your pic and mine, I can see several differences, I used a regular TPH drawbar that is 26" long and my bottom lift arms are centered side to side, the toplink is also centered side to side, then the plow is attached solid to the drawbar and braced to the toplink. I think if you start with a triangular frame centered between your lower lift arms and to your top link with that centered behind your tractor and then mount your plow to that frame it won't put your TPH linkage in a bind and then bend or break something. When you get that one working, find another one like it and I bet the BX would pull a two bottom version.:D
Ok I'm going to try to reply to everyone here in this one message.
The way I attached to the lift arms was I took a 2"x2" square tubing and cut it to the length I needed. Then I took 4 pieces of 3/16th inch and welded them in pairs to simply make them thicker. I did this just because I didnt have steel as thick as I would like it. These pieces went at the end of my square tubing. I welding the square tubing directly to Brinley? hookup that was already on the plow. So there is no movement in that at all. As you can see, I offset my pins when I welded them onto those pieces of steel. I did this by putting the tractor up on blocks that were about 6inches high, and took measurements on the lift arms using a level to get my height difference. I do think though that I did it too drastically because just looking at it looks wrong, and my right side of the tractor is never that low in the furrow. Since the square tubing is solid onto the plow, I am still having a hard time understanding why my plow is bending side to side. Or are you saying with the Brinley setup it made so that it's not solid, so the plow is allowed to bend?
I am planning on making the "A-Frame" system. I have seen them like that, and I wish I did that in the first place, but the way the plow was made it seemed like it would be a bit harder to do. Could be wrong though.
Oh and by the way, I just turned 19. Not too too bad for being kinda young right? I have also made a set of harrows, snow plow that hooks to the bucket, trailer hitch type thing on the TPH, a tray that goes on the TPH and I think thats it. If you would all like to see them I would be happy to put some pictures up.
WHEELBARROW & TOOLS (A58374)
WHEELBARROW &...
Kubota MX5400 (A57148)
TANK MANIFOLD (A58214)
LOT OF OUTDOOR FURNITURE (A58374)
LOT OF OUTDOOR...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2007 FORD F-550 XL SUPER DUTY CHASSIS TRUCK (A58375)
2007 FORD F-550 XL...
