Problem with my LT1024
/ Problem with my LT1024 #1
dcarltonGA
I have owned my LT1024 since May of 2004. I have a little over 4 acres with 2.5 of it grass. Fortunatly I don't have to cut all of that as we also have goats to maintain some of it. In the past 3 summers I have put about 110 hours on it.
Earlier this summer I noticed it seemed to be moving slower than I remembered and seemed to have trouble going up the slightest incline. Reverse seemed fine.
I went with it this summer and it never got worse, but sometimes seemed to get better the longer I used it (the hotter it got), but then towards the end of the cut, if I had a larger hill to climb, it would slowly do it. You could also hear the whine from the transmission as it did this.
A couple of days ago I decided it was time to cut again. It's cooler here in the south so this evening was perfect. Made one pass around the big front yard and it was slow as molasses on a cold day. I was wondering if I would get it cut. I pushed forward and it had the same problem climbing a small incline but as I would make turns, it seemed to figure out I wasn't taking no for an answer. By the end of the cut, it was moving forward similar to early in the summer, but still not like it was when it was new.
Is this a tranmission problem, a belt problem or something else?
/ Problem with my LT1024 #2
I assume the hydro fluid level has been checked? It tends to expand as it warms so that may be why it works better hot.
-Larry
According to the manual, the hydrostatic transmission is sealed at the factory and is maintenance free. The fluid level cannot be checked nor can the oil be changed. Always keep the area around the transmission cooling fan free of grass and debris at all times.
The fan seems to be turning fast, but of course I can't measure how fast, it seems clean there and I don't see any signs of leakage as if maybe some of the oil had leaked out of the factory sealed unit.
/ Problem with my LT1024 #4
Wow. I didn't know they sealed them like that.
-Larry
/ Problem with my LT1024 #5
only on the 1000 series....2000 series and up have the servicable transaxle with the external hydraulic filter....
So any ideas? Besides the shop? I fix most things myself but didn't want to start throwing parts at it in an attempt to figure it out.
/ Problem with my LT1024 #7
I'm not an expert on these things, but it sure sounds like the hydro isn't pulling properly. If it's sealed, I don't know there is anything you _can_ do.
Is it still under warranty by chance?
Maybe Ken or one of the other guys has an idea.
-Larry
I wish it were under warranty. It went out of warranty in March of this year.
/ Problem with my LT1024 #9
There have been some posts concerning other CC's where the forward/reverse hydro pedals get out of adjustment. In other words, you could be pushing down all the way on the forward pedal, but the transmission thinks you're just pushing half way down.
Any chance there could be a similar problem here?
/ Problem with my LT1024 #10
Does it exhibit the same symptom in reverse? If not, it could definitely be a linkage problem.
Bob B.
Reverse seems to be fine. In fact if I could mow grass in reverse, I could probably cut it pretty fast. If it's linkage that should be easy to adjust one would think, if I know what I'm looking for.
Finally got a chance to look closer at my 1024. Played with the linkage and everything looks tight/responsive. Now I don't know what it's supposed to look like and I really don't see anywhere to adjust it. Took of the right rear wheel to get at everything to do this.
Looked at the belt. While not 'worn out' it does have some cuts all from one side to the other in several places. I will have to replace this belt for sure. Would these cuts in the belt account for slow movement?
/ Problem with my LT1024 #13
The operators manual should give instructions on how to adjust linkages. If you do not have the manual that came with the machine, you can down load it from the CC website. Along the left of the CC home page there is a button called "Manuals." Just click on that and find the operators and service manual for your model. You will need the Model and Serial numbers from the tractor. Sounds like a linkage adjustement if you don't see the problem in reverse, but could be in the tranny as well.
You can also go into the CC website under parts and look at exploded views of all of the different subassemblies of the tractor. I looked as the 1042 drive system to see how it was configured. F/N 44 of the Drive System is the Hydro Control Rod. There is a 3/8 ferrule on the pedal end of that rod. If that ferrule started to slide just a little it would reduce the stroke and not give you full speed. Other than that one adjustment, I did not see any other adjustments to drive system, and that would not be temperature sensitive.
You might take a look at the website and see what you can come up with.
/ Problem with my LT1024 #14
If it's not the linkage, the belt or an issue with the spring loaded belt tensioner pulley, then the trouble lies within the hydro transaxle itself. It's no secret there have been some issues with this exact problem in the 1000 series LT's, many of them were the spring and pulley, some were the Hydro-Gear transaxle itself. Check the simple stuff first, most dealers are aware of this problem and should know what item it is right away.
-Fordlords-
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
F-450 SuperDuty Flat Bed 4WD (A63688)
F-450 SuperDuty...
NEW 2025 Mini Skid Steer Stand On Loader (A62679)
NEW 2025 Mini Skid...
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63688)
2023 New Holland...
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
