Problem with Lift Tilt Dump...
/ Problem with Lift Tilt Dump... #61
Since I don't have a set up like yours so I can't say for sure, but the accummulator when it gets its pressure and builds up seems like it might have a check valve[whether piloted or manually released] that holds that pressure and when you cut off the machine it relieves the pressure on the check valve. If it has a check valve then that check valve could have something holding it open and letting it just pump oil straight through it and back to tank. If it has a check valve and it is stuck open then that would cause the problems that you are having. Just thinking out loud without looking at the system that you have, I'm probably wrong about that thought but then again I might be right, and then again who knows [Terry].
I think you are right. I did pull the check valves and no joy. I also have this high pressure filter that is in line with a meter on it that tells if the filter is in good shape or bad shape. This also may be the culprit. Talking to Terry today.
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63118)
2024 Kubota...
2017 Infiniti QX50 SUV (A61574)
2017 Infiniti QX50...
Craftsman T140 Lawn Mower (A64047)
Craftsman T140...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63118)
2023 Kubota...
2002 SHOP 20' FLATBED GOOSENECK (A63569)
2002 SHOP 20'...
