Problem with Kubota LA724 Loader
   / Problem with Kubota LA724 Loader #1
SteveCornell
Weston, West Virginia
2017 Kubota L6060 HSTC
This evening I was rooting out some brush with my grapple when something went "POP" in my loader, now I do not have any curl power, I can curl down and I have power and it holds but when I curl back all goes limp and I have no power back.
I think I damaged something in the cylinders, any ideas ???
   / Problem with Kubota LA724 Loader #2
Curl cylinder is retracting on curl backward!!
Bucket curl forward!!
Does bucket move anything on curl backward??
If NO for backward, piston most likely came off the piston rod inside one of the the cylinders....."POP".....:D
Yes, that is what I suspect, I can lift the front of the tractor off the ground and the valving will hold it in place (extending cylinders out) but there is nothing when I try to retract the cylinders...... Sound like I broke both piston rod ends..... I'll have to remove the cylinders and get them rebuilt :(
   / Problem with Kubota LA724 Loader #4
one piston off is enough to disable both...they are plumbed parallel... if you have a couple plugs for the hoses you can determine which cylinder is bad....OK? do that before starting dismantle the "whole" machine....unhook the hoses on one cyl..,.and check if FEL runs "normal" with the other cylinder....
2011 Hyundai Sonata Sedan (A51694)
2011 Hyundai...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
2002 14ft S/A Utility Tilt Trailer (A51694)
2002 14ft S/A...
1996 FORD F SERIES DUMP TRUCK (A51406)
1996 FORD F SERIES...
2015 HINO XJC740 BOX TRUCK (A53426)
2015 HINO XJC740...
2013 Bandit 200XP Towable Brush Chipper (A51691)
2013 Bandit 200XP...
