problem with Kubota L48 starting
   / problem with Kubota L48 starting #1
l48ed
ashaway, ri
l48
I have a 2008 or 2009 Kubota L48 and it is intermittently not starting. The battery is strong and it cranks well. I had Kubota repair guy at it and he was unsure of exact problem. He told me that he replaced a fuse that "should not have been involved with the starting circuit" but after he replaced it, the engine started. He seems to remember he replaced the "working light" fuse. I just spoke to him and he thinks it may be that a fuel solenoid is not getting enough juice to pull properly. I don't have manual for engine or wiring diagrams. Can anyone tell me if they agree with diagnosis and where exactly this solenoid is located. Also, where can I download shop manuals and wiring diagrams. Thanks much
   / problem with Kubota L48 starting #2
:welcome:
   / problem with Kubota L48 starting #4
I had a similar problem on my L39 and the kubota dealer said it was a bad connection in the fuel solenoid wiring. It took 3 trips to dealer for them to finally find and "fix" the problem. They either replaced or re-crimped the connection and no problems since. Phantom wiring problems are hard and frustrating to find. Be sure to check all wiring where you have a connection to chassis ground. A shop manual with wiring diagram will show all those points as well a the fuel solenoid circuit. Let us know what you find. Good Luck!
   / problem with Kubota L48 starting #5
Welcome to TractorByNet from Tennessee.
   / problem with Kubota L48 starting #6
Welcome to TractorByNet!
I moved your thread to the Kubota Owning & Operating forum. :)
2021 John Deere 6130M 4WD Tractor w 620R Loader, Premium Cab, 250 Hours (A51039)
2021 John Deere...
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
2013 Ford Expedition XLT SUV (A50324)
2013 Ford...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
100 GAL L SHAPED FUEL TANK (A50854)
100 GAL L SHAPED...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
