problem with kubota g2160
   / problem with kubota g2160 #1
bubba402
Bucyrus, Ohio
Kubota g2160
I bought a used Kubota g2160 last year. Works and mows great. At the end of the mowing season the 2160 started losing power and rpm's after it had been running about twenty minutes. Sometimes it would shut down, other times it would sputter awhile, then run smooth again for a short time before losing power again. I explained this to my mechanic who gave the 2160 a spring going-over this spring. The mechanic said he was unable to replicate the problem but said that the fuel filter was clogged. The 2160 ran great again this spring, but now (starting today) it is doing the same loss-of-power thing. I changed the fuel filter (maybe there was some residual dirt or debris from the tank). After about fifteen minutes of quality mowing, the engine is sputtering again. Anybody have any ideas or solutions?
   / problem with kubota g2160 #2
I would drain and clean the fuel tank. It sounds like there is debris in the tank clogging the filter.
Did you change BOTH (2) fuel filters.
David Kb7uns
no I didn't. I didn't know there were two fuel filters. Can you help me out? I changed the one that was on the left side of the engine. It was held in place with a metal clamp. Thanx.
I found the second filter that you put me on to, I will try to change that one also and see how it does. Thanks.
   / problem with kubota g2160 #7
That probably is your problem, if the first filter is clogged bad or you are using fuel treatment you will get water in the second filter as the electric lift pump will suck water through the first filter.
Last time I changed mine I took the tire off and it made it easier.
David Kb7uns.
   / problem with kubota g2160 #8
David Kb7uns.
I also take that tire off to change the hydro filter.
2017 Ground Hog HD99 Towable Hydraulic Auger (A49461)
2017 Ground Hog...
1997 EZ S/A Spool Trailer (A49461)
1997 EZ S/A Spool...
2016 New Holland Boomer 47 4WD Front Loader Utility Tractor with Bush Hog BH16-2 (A50322)
2016 New Holland...
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A49461)
2018 JLG 1644 4x4...
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
