PROBLEM WITH JOHN DEERE 755
   / PROBLEM WITH JOHN DEERE 755 #1
rch56
Sandusky, Mi
john deere a
WE JUST PURCHASED JD 755. TRACTOR WILL START BUT ACTS LIKE ONLY RUNNING ONE 1 CYLINDER. SHAKES TERRIBLE, AFTER 2 TO 3 MINUTES PICKES UP OTHER CYLINDERS AND RUNS GOOD. CHECKED FILTER, FUEL LIFT PUMP TO INJ PUMP.GOOD FUEL FLOW TO INJECTION PUMP. ALSO NO THROTTLE RESPONSE TIL PICKES UP OTHER CYLINDERS. THINKING IF BAD INJECTOR OR PUMP IT WOULD NOT RUN RIGHT AFTER WAITING 2 TO 3 MINUTES. WHAT SHOULD I CHECK NEXT
   / PROBLEM WITH JOHN DEERE 755 #2
Makes sure the all the fuel system lines are tight. It sounds like your getting air in the fuel system somewhere and the engine runs correctly once it clears the air out.
MAGNUM PRODUCTS LIGHT TOWER (A50854)
MAGNUM PRODUCTS...
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
2016 Ram 1500 4x4 Crew Cab Pickup Truck (A49461)
2016 Ram 1500 4x4...
2013 Ford Expedition XLT SUV (A50324)
2013 Ford...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2018 DODGE RAM 2500 (A50854)
2018 DODGE RAM...
