Problem with john deere 300cx loader
   / Problem with john deere 300cx loader #11
You should expect some movement due to it being a QA loader.
Is it more then it was at one time (when new)?
Consider the problem may not be in the locking mechanisms...might be in the frame mounts or elsewhere.
Did you install you loader yourself? I suggest you check all mounting hardware...go step by step per the loader's installation instructions.
   / Problem with john deere 300cx loader #12
Did you take the loader off the tractor recently ? Have you checked it is properly seated and the hooks have come up properly under the front bumper ?
   / Problem with john deere 300cx loader #13
Check all your QD for the loader. Unplug and reset them.
Have you checked hyd pressure anywhere?
2023 KAWASAKI MULE (A51243)
2023 KAWASAKI MULE...
2013 Ford Econoline E350 Passenger Van (A49461)
2013 Ford...
Memo 98 Loader with Brackets (A50514)
Memo 98 Loader...
196046 (A50459)
196046 (A50459)
INGERSOLL RAND 100KW GENERATOR (A50854)
INGERSOLL RAND...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
