Problem with Hydraulics
   / Problem with Hydraulics #1
fcamillieri
Bronze Member
Chester, NH
CK20HST
The lever to run the BH doesn't stay engaged. It used to but now I have to use a bungee to hold it in. Is there something wrong or an adjustment I can change?
Thanks,
Frank
   / Problem with Hydraulics #2
I don't get it? The backhoe doesn't stay engaged? Huh?
I'm probably just having a dense day..
   / Problem with Hydraulics #3
Sounds like he has rear remote hydraulic connections and the valve that controls the flow is no longer staying in it's ON detent position.
Will it not stay in either the A or B position or just the A position?
   / Problem with Hydraulics #4
There is an adjust for the detent pressure. My CK 25 went the opposite way and it was so hard to move that I bent the lever. Works perfect after I tweaked the detent spring pressure.
Won't stay in either position. I'll look for a detent adjustment.
Thanks,
Frank
2013 Infiniti JX35 AWD SUV (A50324)
2013 Infiniti JX35...
JMR Attachments Tree Boom (A50121)
JMR Attachments...
2000 International 4700 Truck (RUNS) (TITLE) (A50774)
2000 International...
2016 Takeuchi TW40 Wheel Loader (RIDE AND DRIVE) (A50774)
2016 Takeuchi TW40...
2002 Sterling M7500 Acterra Lift-All LA04C51 51FT Insulated Forestry Chipper Bucket Truck (A50323)
2002 Sterling...
2002 John Deere 5220 (A50120)
2002 John Deere...
