Problem with FEL joystick
/ Problem with FEL joystick #1
pmoon
Finger Lakes, NY
L3430
My joystick will not move to the right (723FEL). So...bucket will go up, down, and I can roll the bucket back but not down. It's not that it will move to the right and nothing happens - it won't move to the right. It's been cold (teens) for the past few days. Any ideas???
/ Problem with FEL joystick #2
Just shooting from the hip, try disconnecting the hoses and reconnecting.
/ Problem with FEL joystick #3
Mine did a similar thing on the up and down, not the curl. It was ice in the detent thingy. Look on bottom of the joystick. There should be two large hex things, 1-3" long. Unscrew them (no oil will come out) and look inside. If you see rusty colored junk in one, that is the one with condensation inside, which freezes. Dealer told me to drill a 1/16" hole in bottom for water to run out. I did that, warmed it up, sprayed carb cleaner in there, then compressed air (repeat several times) to get out the water polluted grease, sprayed aerosol lithium grease in there, and voila! No prollems since, even in -18F temps. Might be your prollem.
Thanks - as usual - such great posters/website...
/ Problem with FEL joystick #5
Be very careful taking the caps off. Some of the valves have very small bearings in them that can get lost easily.
/ Problem with FEL joystick #6
I had a similar problem on my B7100HSt loader last month. It would go up but not down. The curl function worked well.
I just let the tractor warm up and then cycled the curl to warm up the control block. Took a couple of minutes and then all the joystick functions worked. /forums/images/graemlins/grin.gif
First time that had ever happened to me.
Egon /forums/images/graemlins/grin.gif
Caterpillar Traxcavator parts books (A63117)
Caterpillar...
2024 Kubota SVL97-2 High Flow Compact Track Loader Skid Steer (A61572)
2024 Kubota...
Bish Wide Body Claas Adapter Kit (A63117)
Bish Wide Body...
2010 Cadillac CTS Sedan (A61574)
2010 Cadillac CTS...
Case Titan 3530 (A63688)
Case Titan 3530...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63689)
2017 Yale GLC050VX...
