Problem with dual counterbalance .
/ Problem with dual counterbalance . #1
hodinhtran
Good day Sir,
I got problem with dual counterbalance valve . My dual counterbalance valve comprise 2 relief valves. The valve is mounted direct on motor of the winch, and its position is between the motor and the tandem directional valve. there is no problem as the load is light. As the load is heavy I must tighten one of the screw for adjusting pressure of system, and the winch can raise up the load, but as lowering the load, the winch can not operate smoothly. And when I loosen the screw, the winch can lower heavy load smoothly but it cannot raise up the heavy load.
So, please guide me to adjust two of relief valve for operating smoothly of the winch . Does I use the tandem directional valve effect the un-smoothly operating of the winch? I should replace type of open directional valve for tandem type ?
Thanks you very much
/ Problem with dual counterbalance . #2
I have never seen an adjustable counterbalance valve. It sounds like each "relief valve" is acting on the flow in both directions, instead of only one like in a counterbalance valve. I true counterbalance valve has zero restriction in one direction but restricted in the other, the amount determined by the pressure ratio. ISZ
/ Problem with dual counterbalance . #3
Why not use a cross-port relief valve instead of the counter balance valve.
/ Problem with dual counterbalance . #4
Hodintran... can you please check who the manufacture of the valves are??? there should be a model number on them.. we need to know before anyone can help??
is it a Sun CBCB valve Sun Hydraulics
or a Sun MBEB valve Sun Hydraulics
or a Sun RBAC valve.. Sun Hydraulics
as you see they are all different but the same??? Jim
2020 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A61573)
2020 Peterbilt 579...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2023 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59912)
2023 UTILITY VS2RA...
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
2014 Freightliner M2 112 Tandem Dump (A62613)
2014 Freightliner...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
