Problem with Blade cylinder on Bobcat 334 excavator
   / Problem with Blade cylinder on Bobcat 334 excavator #1
wingfootedgodhead
nyssa, or
bobcats
Symptoms - When running at normal operating temperature, blade cylinder extension has no 'power' and will not anchor / pick up the front of the excavator. When running 'cold' at start up - no problems at all with this function.
The blade cylinder is a new part, but I seem to remember having issues with the old cylinder.
Am I looking at replacing the the hydraulic control valve ? With the theory that the valve is not closing all the way and allowing hydraulic fluid to bypass the cylinder ?
   / Problem with Blade cylinder on Bobcat 334 excavator #2
Either the cyl or the valve spool is bypassing.
Yo might also look at the cap on the bottom of the valve and see if the spring centering springs are good and the nut is tight.
Do you have PB? Power Beyond circuit.
If so, remove the return hose and with the lever at neutral and engine running, is there any fluid flowing from the out port.
Logically, in neutral, and all things good, all the pump flow should be flowing trough the valve and to the tank with little or no pressure.
2008 Chevrolet Uplander LS Van (A51694)
2008 Chevrolet...
2005 Frieghtliner 18' Box Truck (A52377)
2005 Frieghtliner...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
Scag STT61V 61in Zero Turn Mower (A51691)
Scag STT61V 61in...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
