Problem with 20# propane tank valve
/ Problem with 20# propane tank valve #1
Robert_in_NY
Super Member
Silver Creek, NY
Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
I had two 20# propane tanks filled at the feed mill a few weeks back when it was in the single digits temp wise. The one tank was overfilled I am thinking as as soon as it warmed up it was hissing. However, I can't get the fuel to come out of the valve. I have hooked heaters up to it and even just opened the valve with nothing on it to see if the gas would come out. This is the older style valve and not the new mandatory valve required for most everyone else. We use these tanks for farm/construction use which is allowed. So does anyone have any ideas? I can get a pic of the valve tomorrow as it has one screw on the side of the valve but I don't want to mess with it as I have no idea what it is for. Is this something simple to fix or do I have 20 pounds of propane that is now trapped permanently?
/ Problem with 20# propane tank valve #2
I believe the screw is a vent screw normally used when filling the tank.
Might try letting some gas out and try the valve again.
Could the valve be frozen? That can happen with moisture in the tank.
The valve may have been frozen initially but it has been stored in an area around 50 degrees for a couple weeks and still didn't work. The valve feels like normal when you turn it to open it but it acts like its plugged as no gas even starts to leak out of the valve when its open.
/ Problem with 20# propane tank valve #4
A lot of propane valves have overflow protectors, which stop propane from escaping if someone opens the valve with nothing attached. I don't know exactly how they work, but there could be some kind of interaction with overfilling and the overflow protector. This is separate and different from the new overfill protection valves.
Either take the tank back, or if you are feeling adventurous, take the tank outside, to a safe area and open the little screw to bleed off some of the overfill. Standard precautions about flames, ignition sources etc. apply.
/ Problem with 20# propane tank valve #5
Robert,
If I ever get one of those tanks without the OPD valve on it, I just take it to Walmart and do a swap. They never notice and give me a tank with the new OPD valve.
Then I have a tank that I can take and get filled.
Chris
/ Problem with 20# propane tank valve #6
OPD valves for sure have this feature. Before OPD I had a tank with the feature and ended up having to change out the regulator on my BBQ as, for whatever reason, it would no longer seat properly to allow gas out. Worked fine on another tank though so...
Robert, have you tried hooking something else to the tank? i.e. weed burner etc. and see if that works?
Robert,
Chris
I can get our tanks filled that don't have OPD valves on them. We do not actually want the OPD valve for our torches. We can get our tanks filled at any fill station as all we have to do is show them the tag on our tank saying that it does not have an OPD valve and that we use it for construction use which allows it to be filled. The OPD valves are for homeowners.
I have hooked two different style heaters to this tank and neither would work. I think the valve froze and one of our workers snapped the stem. I opened the screw on the side and drained off a lot of pressure and the valve still never opened so I just left it open and let it drain out.
And maybe they should be for contractors as well...:D :D for the reasons you are having the problem.
The problem with the OPD valve is it doesn't allow our roofing torches to work properly.
/ Problem with 20# propane tank valve #11
Not enough flow? IIRC that is a common complaint with those who run high BTU devices from tanks with the new valves.
Aaron Z
Aaron Z
Exactly, the OPD valve is designed to limit the flow and when heating modified rubber roofing you can't have your tank acting empty when its still full. Even some of our heaters pull too much for the OPD valve.
The guys at the fill station said they get a lot of half full tanks in to be filled because the guys think the tank is empty because the valve won't let the fuel out fast enough to work properly.
/ Problem with 20# propane tank valve #13
The worst thing about these tank is when a heater explodes you run to the tank to shut off the gas and the valve turns to the fully off position but the gass keeps on pouring out of the tank.
Iam Clamp On Bucket Trash Spike Attachment (A64912)
Iam Clamp On...
TAG 35" QUICK ATTACH EXCAVATOR BUCKET (A65053)
TAG 35" QUICK...
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
2015 KUBOTA F3990 MOWER (A66091)
2015 KUBOTA F3990...
