Problem overheating
   / Problem overheating #1
nikos
Greece
A friend of mine has an old Kubota L245 (25 years old) tractor and lately it overheats after driving it a bit. There is coolant and he has cleaned the fridge system of the tractor a few months ago. I suspect the coolant pump. Do you have any other suggestions? Thanks!
   / Problem overheating #2
Over time the cooling fins go on the radiator so replacing that would be one solution. I take it he did the obvious stuff by blowing out all the hood vents, screens and radiator fins with compressed air?
imo the tractor should not overheat that quick if it's not under load so that sending unit 'could' be bad...just double check it with the proper thermometer to be sure.
INOP/NON-RUNNING 2008 International 7300 Truck, VIN # 1HTWAAAN78J690166 (A51572)
INOP/NON-RUNNING...
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
American Farmworks 15 Mile Fence Controller (A51573)
American Farmworks...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
Turfco...
