Problem overheating
   / Problem overheating #1
nikos
Greece
A friend of mine has an old Kubota L245 (25 years old) tractor and lately it overheats after driving it a bit. There is coolant and he has cleaned the fridge system of the tractor a few months ago. I suspect the coolant pump. Do you have any other suggestions? Thanks!
   / Problem overheating #2
Over time the cooling fins go on the radiator so replacing that would be one solution. I take it he did the obvious stuff by blowing out all the hood vents, screens and radiator fins with compressed air?
imo the tractor should not overheat that quick if it's not under load so that sending unit 'could' be bad...just double check it with the proper thermometer to be sure.
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
Ingersoll Rand Air Compressor (A51573)
Ingersoll Rand Air...
2023 LMC M30018 LOT NUMBER 207 (A53084)
2023 LMC M30018...
2016 RAM 3500 HD SERVICE BODY TRUCK (A52576)
2016 RAM 3500 HD...
FRONTIER AH11G LOT NUMBER 112 (A53084)
FRONTIER AH11G LOT...
JCB 507-42 Telehandler (A51573)
JCB 507-42...
