Oil & Fuel Problem: Oil spitting out of.... on my Ford 841
   / Problem: Oil spitting out of.... on my Ford 841 #11
Mark, it sounds like you're on top of this and have the problem figured out. I also think you are lucky to have a good mechanic who will work with you and show you what he is doing. That's a confidence builder.:thumbsup:
I did a compression test and had the following:
- Dry - 1-148, 2-135, 3-135, 4-150
- Wet - 1-170, 2-150, 3-150, 4-163
Given the age of the age of the tractor I assume i am good to go.
   / Problem: Oil spitting out of.... on my Ford 841 #13
yep.. plenty psi to get some work done..
   / Problem: Oil spitting out of.... on my Ford 841 #14
I agree. . . no significant problems there. Just an indication of normal wear for a 45+ year old engine.
Found it - thanks to the gentleman who supplied me the long parts list for the pump. I need a EAF17375D ADAPTER Adapter Set Wow! They want $40 to $60 bucks for one of these! TXs for the previous info!
Added to post below: The proofmeter works when I spin it with a drill. The pump end of metal cable is round with a notch. The pump side is a large, female standard screwdriver like notch (see 3rd picture in original post) - no way these match. Am I missing something? I checked pictures on 3 different parts web stores and the metal cables appear to have the round with a small notch at the end - so I am assuming I have the correct cable for the 841 Hyd pump.
I got my repaired hydraulic pump back and purchased a proof meter and metal cable. Installed the pump (and changed all the fluids - engine/filter, hyrdaulic, rear axle, tranny,...). Runs great, no leaks, no oil spitting out.
How ever, my proof meter (never had one) does not indicate anything. I was pretty sure I inserted the end into the slot on the pump (unless it slipped off), but just not sure if I am hooking up the cable correctly to the female notch in the pump, or, the other end into the proof meter. I can't find any instructions on the internet. Can anyone help me walk through the proper way to do this (I assume the electrical hookup is for a light, and has nothing to do with the proofmeter working).
Help :)
Mark
   / Problem: Oil spitting out of.... on my Ford 841 #16
is there a lil roll pin in the end of the pump side of the drive cable?
I installed the "adapter" connecting the proofmeter cable to the hyd. pump. All is sealed and working. TXs to everyone who helped me muddle along, it was extrememly helpful and I learned a lot! I am not hesitating to use this resource again.
Mark
   / Problem: Oil spitting out of.... on my Ford 841 #18
post back if you hit a snag. them 55-64 machines are super easy to work on.
14179 (A55788)
14179 (A55788)
1996 Timpte 46ft Hopper (A55315)
1996 Timpte 46ft...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
2023 BOBCAT T770 SKID STEER (A52709)
2023 BOBCAT T770...
