Pat's Easy Change problem disconnecting Pats Easy Change
   / problem disconnecting Pats Easy Change #1
rico304
Cumberland County, Maine
JD 4300 w/ FEL
I've searched and tired of reading through posts. SO... this is my problem.
I have the Pat's Easy Change system on my JD. I don't have the instrucions for them.
To release, you have to pull up on the lever. As you lift lever on easy change up, the piece that holds the implement in place is supposed to retract into the easy change system. Works great with no implement on it. When there is an implement on/in system, I cannot pull the lever (on system) up all the way. I see it catching on the implement pins. Sorry about poor explanation.
Hope you know what I'm trying to say.
The implement pin doesn't allow the easy change to retract. I have to keep re positioning the implement. I can get one off, but the other one won't release.
If you understand my jumbled post, please explain it to others better by using proper terms! hahaha
Is there some adjustment to make lifting the easy change release lever easier?
I do lower my 3ph all the way, but maybe it might help if I off load implement onto a pallet? I'll give it a try this weekend. Thanks!
   / problem disconnecting Pats Easy Change #3
My Pat's sticks some on my KK rake, mainly because the pins are not straight. I have no problems if I lift the rake up before I open and lock the easy change. Then let it down on the ground. JC
   / problem disconnecting Pats Easy Change #4
Implement pin location is a consideration too. I've got a dozen or so various implements that I use with my PEC. No two have identical pin heights. When dropping one implement in favor of another, I'm often adjusting the vertical distance between upper and lower lift arms. This adjustment is independent of the hydraulics.
//greg//
   / problem disconnecting Pats Easy Change #5
When you lower all the way is it on level ground? If not, there might still be some tension on the pins to the latch?
Also check to see if PEC is on square on your lower drag links. If they are a little cocked they could also bind a little.
   / problem disconnecting Pats Easy Change #6
rico304,
I installed the PEC Friday after Thanksgiving and immediately noticed the same problems your are having. I realized when there is an implement attached to the tractor and raised off the ground, the tail weight of the implement forces the lift pins forward and up into the latch lever of the PEC, preventing them from being opened. If the implement is on the ground and unlevel, or there is no weight on the lift arms the latch lever will also bind and not open. What you need to do is drop the implement to the ground and unhook the top link first. Raise the implement a few inches off the ground and unlatch the PEC, then lower your lift arms from the implement. Once I figured that out after the first time it happened, I haven't had that issue since.
Hope this helps.
Joe
   / problem disconnecting Pats Easy Change #7
So far, no problems unhooking from Pat's Easy Change. Something I do that may (or may not) help is disconnect the upper link first, then the PTO shaft (if rigged)...then disconnect from the Pat's Easy Change.
Hope this helps you folks...
Oops...I see GIJoe beat me to it.
Awesome! I'll give it a try and report back
   / problem disconnecting Pats Easy Change #9
Make sure they are square and level.
1 Set the gap between them at about 26" for a cat 1 tractor.
2 Get a 1" pipe and put in both side at the same time. Larger than the 7/8 pin diameter.
3 Set the lower arms level with a level.
4 Shim the bottom of Pat's system level.
5 Square with the adjusting bolts.
I also use a wrench to increase my leverage on the release arm if needed.
   / problem disconnecting Pats Easy Change #10
rico304,
you can check out the instructions for PEC at this link:
New Page 2
Let me know if you are still having a problem, if so just call me at 888-243-4204 and maybe we can help.
Thanks
Pat of Pat's Easy Change
John Deere Quick Attach Bale Spear (A50514)
John Deere Quick...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
John Deere 7500 Reel Mower (NOT RUNNING) (A50774)
John Deere 7500...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
7' Snow Blade (A50515)
