Mowing Problem adjusting the cutting deck height
   / Problem adjusting the cutting deck height #1
Elwyn Frey
I have a 2210 with only 325 hours on it. No hard use. I'm having a problem getting the height adjustment knob to work. I've tried adjusting the big "turnbuckle" to the setting in the owner's manual: 24.6 inches from end hole to end hole on center. That's just about as short as the turnbuckle will go. At that position, the adjustment knob won't turn. I've adjusted the rod out in small increments until it is way out, and still nothing. Right now, the height adjustment knob is stuck and doesn't turn at all no matter where the rod is and the deck is up at the high end and will not come down. The lift arms in back work fine and they are adjusted to raise/lower the deck, but it's still not working. What am I not seeing???
   / Problem adjusting the cutting deck height #2
Have you tried making the turn buckle longer? It sounds like the mower deck is not raising high enough to take the pressure of of the adjusting knob.
Is there something above the deck that is not allowing it to raise all of the way?
Have you tried manually raising the deck & supporting it with blocks to take pressure off of the adjustment knob? Doing this would allow you to see if the problem is with the adjusting knob alone.
Here is a link to JD parts on the 2210 adjusting knob. The arm on part 16 rests on the adjusting knob when the deck is lowered.
John Deere Parts Catalog
Chevy, thanks! I was able to turn the adjustment lever and get things going again. I took the rod off and cleaned it up and will be reinstalling tomorrow. Thanks again!
   / Problem adjusting the cutting deck height #4
Welcome.
Willmar 4300 Wrangler Loader (A52128)
Willmar 4300...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A52141)
2004 HYUNDAI...
2009 MACK ELITE MRU613 GARBAGE TRUCK (A51243)
2009 MACK ELITE...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2014 CATERPILLAR CB54 XW SMOOTH DBL DRUM ROLLER (A51242)
2014 CATERPILLAR...
