Probably minor problems...
   / Probably minor problems... #1
Bob_Trevithick
Platinum Member
Williamson, NY (near Rochester)
JD 4300 MFWD
Two things on my new JD 4300...
-I opened the fuse box cover to take a peek, and now it won't close properly. No matter what I do, after folding down the lock, it just flops open.
- Looking at the rear of the tractor, the two draft arms appear misaligned. With both of the draft bars set to the same pin position, the left arm is much closer to the tire than the right arm. Did something get bent, or is this okay?
Note that I got this as a new machine, but it had about 20 hours on it as a "demo". I got a discount. Who knows what it was subjected to before I got it? Is this something to be concerned about?
Thanks,
Bob
Bob Trevithick
   / Probably minor problems... #2
Do the arms have stabilizers on them that are adjusted to different lengths, or are they free swinging?
<font color=green> MossRoad </font color=green>
<P ID="edit"><FONT SIZE=-1>Edited by MossRoad on 12/12/01 10:23 PM (server time).</FONT></P>
<font color=blue>...Do the arms have stabilizers on them that are adjusted to different lengths, or are they free swinging?</font color=blue>
The arms have stabilizers, which are adjusted to the same pin positions. I would say the whole thing is misadjusted about an inch to the left. I think I could probably get it even, but haven't tried yet. I'm new to this, and just wondering if the machine got bent somehow before I got it.
Thanks,
Bob
Bob Trevithick
   / Probably minor problems... #4
My stabilizers are screw adjustment, as are the height adjustment for the lift arms. You might want to measure them instead of counting the pin holes to see if they are even.
<font color=blue>...My stabilizers are screw adjustment, as are the height adjustment for the lift arms. You might want to measure them instead of counting the pin holes to see if they are even.</font color=blue>
Well, I may be confusing terms here. I think the bars I'm refering to are called "sway bars"?
I have (and I remind you that I'm a complete neophyte) an adjustable right link, that is a screw thing. I think this adjusts the implement horizontally .. to an even position. Then, in addition, I have what I believe are called sway links, which limit right to left movement of implements. These are both adjustable via pin positions.. and are both set to the same pin hole.
Why would the draw bars be closer to one tire than another?
Sorry if I'm muddying the waters by confusing my terms. I'm referring to a bunch of manuals..
Bob
Bob Trevithick
   / Probably minor problems... #6
That's right. The sway bars prevent the lift arms from swinging left to right. Measure them with a tape measure to see if there is the same distance between where they attach to the tractor and where they attach to the lift arm, regardless of the pin holes.
   / Probably minor problems... #7
Here's a possibility, don't the tires have different positions? Maybe one side is set further out than the other? It may not be the links.
<font color=blue>...Here's a possibility, don't the tires have different positions? Maybe one side is set further out than the other? It may not be the links.</font color=blue>
I looked at that.. the manual says if the valve stems of the tires are on the outside, then they are in the wide position. Both of them have the valve stems on the outside. And both tires show the arrow (direction of turning) correctly. When I get home, I'll measure those sway bars..
Bob Trevithick
   / Probably minor problems... #9
Bob, On my 4300, one arm is always a little closer to one wheel than the other if I use the same pin holes on each side. I usually put the pin in a hole on one side, and then use the slotted hole on the other side, allowing a little movement. It's possible that an arm could be bent, but it sounds like you're wanting everything to match exactly (no offense, I'm the same way) That's why there are so many adjustment holes-so it can be set wherever it needs to be.
   / Probably minor problems... #10
If you have the R-4s on your 4300 the wheels are actually wider if the valve stems are toward the inside. The overall difference is only about 1.5". If you dont have R-4s then disregard this post./w3tcompact/icons/smile.gif
72% of all statistics are made up./w3tcompact/icons/smile.gif
2016 JOHN DEERE 35G EXCAVATOR (A51242)
2016 JOHN DEERE...
2020 ASV VT70HO Skidloader (RIDE AND DRIVE) (A50774)
2020 ASV VT70HO...
3001 (A51691)
3001 (A51691)
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2018 INTERNATIONAL...
