Buying Advice Probably going to buy a ZD331 60" tomorrow
   / Probably going to buy a ZD331 60" tomorrow #1
galevin
Indianapolis
none
I have 6 A which is mostly flat but there is a 10' tall x 20' wide (appx) "property concealment" hill around 1/2 of the property. My buddy just bought 1 of 2 used 2013 ZD331's and I'm looking at the other used one in the morning. Has less than 200 hours and is for sale at a dealer for $9250 financed. Serviced ready to go. This price is hard to beat and with this being freshly serviced, small down and $225/mo and almost new I find it hard to pass up. Unless I can get other opinions talking me out of it, I'm going to test drive it and probably buy it. My small hill that surrounds most of my flat property I can mostly cut lengthwise so not too worried about the hill. What do you guys think? Should I pull the trigger? I bet I will only put 75-100 hours on per season. Thanks for any comments.
Gerald
   / Probably going to buy a ZD331 60" tomorrow #2
Got a similar deal last summer except mine is the ZD326 with 60" commercial deck. About 348 hours or so, one non-commercial owner. $9200 out the door.
You'll love it!
If you use it on hills, fill the rear tires. About 8 gallons each, about 65 lbs each, 130 lbs total. Seems a lot more stable to me.
Good luck.
Fill the rear tires with what? Water?
How do you put water into a tire ?
Gerald
   / Probably going to buy a ZD331 60" tomorrow #4
Don't know about mowers but most tractors use either beet juice, calcium chloride, or a mixture of water and anti freeze. Use environmental friendly anti freeze so if it leaks out animals or the environment will not be hurt.
   / Probably going to buy a ZD331 60" tomorrow #5
Gerald
I use water and RV antifreeze. I used about one gallon per tire, but I live in SC TN. Where you live, you might want to use a bit more.
I used a tire quick fill adapter; I got mine at Gempler's but Tractor Supply has them as do others. Quick Fill Tractor Tire Attachment | GEMPLER'S
Youtube has numerous videos on how and why to fill a tractor tire. And here's some more info: 6 Reasons to Liquid Ballast your Kubota’s Tires | OrangeTractorTalks
Good luck.
   / Probably going to buy a ZD331 60" tomorrow #6
Filling the tires with water/antifreeze may help the grip on hills, but it will also make it ride more rough. Most zero turns don't need anything that makes the ride any rougher.
Skid Steer (A51691)
Skid Steer (A51691)
Kubota SVL75-2 (A50120)
Kubota SVL75-2...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
