pro issue JD 2520r
/ pro issue JD 2520r #1
Lightmechanic
Fort Worth
Mahindra 2815
I have a 2014 John Deere 2025r tractor with 62 mowing bed. Just went to mow the lawn for the first time this season and found that the PTO will only come on for 15 seconds and then shuts off. Any thoughts on what might be wrong? Battery is showing 12.2 volts, Rear PTO switch is showing 12 volts, seat switch is working, back up switch is working. I can not seam to be able to find the PTO solenoid. Anyone know where it is?
/ pro issue JD 2520r #2
Depends on your s/n. Early tractors in the hyd pump, late in a manifold on LH side near rear axle.
/ pro issue JD 2520r #3
At 12.2 volts, your battery is only 60% charged. Trying to trouble shoot an electrical problem will be a waste of time until you have a fully charged, known good battery. I'd pull the battery, fully charge it (12.6 volts at rest) and get the battery load tested to prove it is good. Most auto parts stores will load test for free.
It is entirely possible that once a fully charged good battery is installed, your problem will go away.
Tool Bar (A64127)
Tool Bar (A64127)
LAYMOR SWEEPMASTER 400 (A65643)
LAYMOR SWEEPMASTER...
Stout Utility Grapple XHD84 (A66285)
Stout Utility...
84in. Skid Steer Bucket (A65640)
84in. Skid Steer...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
